intake manifold gasket question
318DodgeRam
Is it possible for coolant to be burned because of a bad intake manifold gasket? I did a block test and no exhaust gases were found in the coolant. I heard it cud be coming from the intake. Is that possible?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Eh, not really. More likely than not you have a cracked head that's causing it. The way to figure that out is to do a compression test on the engine to find any offending cylinders.
318DodgeRam
Alright. I was hopin a cracked head wasnt gunna be the problem. Goin to get a compression tester now.
