Issues with Side door emblems on 2016 ram 1500
gorourke002
Chico, ca
5.7 liter hemi
Hi I bought a ram 1500 used and all exteriors features seemed great until the emblems on side door began to fall off one by one. I realized there was some kind of after market glue keeping the ram 1500 lettering emblems on and now there is a ton of residue underneath that won’t come off with heat or goo gone or anything I have tried.
I’m just looking for advice on either helping to remove the glue underneath or maybe an emblem idea to cover up the ram 1500 outline of glue
Just a side note I went to an auto body shop and they said I may have to sand it down and get it repainted but that seems overkill to me
Tia
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Try and eraser wheels to remove the goo.
But you can have the truck sanded and buffed on that door to maybe remove the haze, or outline. If it doent, you can always get new black, or chrome new badging and put back on?
Hanover Fiste
NW Florida
2005 SLT, 2018 Sport
Try WD-40 or Naptha to remove the glue residue.
MADDOG
Out Exploring Arizona
A 3M rubber wheel should do the trick. If the grit line is persistent try some light rubbing compound.
After removal of the residue clean the area well with an adhesive remover then wax & polish.
averageguy
Belleville Mi
hemi
Be careful with the rubber wheel. If you apply too much pressure or hold it in the same spot too long it can burn the paint.
Rlaf75
East Hartford CT
I dont know what type of adhesive was used but the stock badging or emblems are usually held on with 3m double sided tape. Like mentioned above, be very careful using one of those eraser wheels because you can seriously mess up the paint if you don't know what you're doing.
