key comes out when car is on, omg freak out.
Discussion in 'General Discussion' started by jsl6v8, Jan 4, 2014.
  1. jsl6v8
    jsl6v8 Senior Member
    591
    66
    Jan 31, 2013
    Virginia Beach for the moment
    Ram Year:
    2013 Ram 1500 HFE RCSB
    Engine:
    3.6L V6 And proud.
    Ok, I'm not really freaking out but its not suppose to do that and I'd like to fix it. So what happens is I turn on the car or move it to aux or whatever have you and then I'm able to remove the key. It doesn't turn off the car or anything in fact the car seems to give no indications it realizes the key isn't there at all. Its sometimes an issue mainly because sometimes when I turn the car off I still get that annoying beeping when I open the door telling me my key is still in even when its not. One time though I thought it was just that and left my lights on, didn't kill the battery but it took a little to turn over. Is this an easy fix? is it a symptom of a bigger problem? I need your help, suggestions, tips or a fix action would be very much appreciated, if you have a fix action with pictures and its cheap/easy to do I'll say a little prayer for you every night.
    Crap wrong forum... its a 2001 can a mod move it to 2nd gen please...my bad, couldn't find an option to delete.
  2. NYCruiser
    NYCruiser Senior Member
    2,565
    789
    Dec 17, 2013
    Yonkers, NY
    Ram Year:
    Engine:
    I've seen this happen to old cars, like 60's and 70's, when the ignition switch gets warn. It doesn't hurt anything, other than being able to remove the key while its running from what I've seen.
    If you have a spare key, you should try it to make sure it isn't an issue with the key you're using.
    If its the switch you could get a new ignition switch installed. A locksmith could probably rekey so the same keys still work.
    emjohn4 likes this.
  3. jsl6v8
    591
    66
    Jan 31, 2013
    Ram Year:
    Engine:
    3.6L V6 And proud.
    Yeah I have 3 keys does it with all of them, you said the word locksmith but I saw $lock$mith$ if thats the case I'll probably just deal with it. I was hoping more along the line of there is some washer or plastic piece lose or a screw that needs tightening, you know simple cheap stuff.
  4. emjohn4
    emjohn4 Senior Member
    831
    226
    Jul 25, 2012
    Ram Year:
    Engine:
  5. jsl6v8
    591
    66
    Jan 31, 2013
    Ram Year:
    Engine:
    3.6L V6 And proud.
    oh sweet, sorry I misunderstood the first poster, so a new cylinder would come with keys so I'd just chuck my old keys and have new ones, that works for me, I may do this, thanks for the help!
  6. emjohn4
    831
    226
    Jul 25, 2012
    Ram Year:
    Engine:
    Yup, it'll come with two new keys. You'll just have a different key for the doors and ignition.
  7. NYCruiser
    2,565
    789
    Dec 17, 2013
    Yonkers, NY
    Ram Year:
    Engine:
    Don't chuck you old keys unless they don't open anything else…..like the doors, tailgate, or storage. The new keys that come with a new lock cylinder won't fit any of those other things. That would be the motivation to get it rekeyed to your existing keys.
  8. iSlacker816
    iSlacker816 Senior Member
    2,519
    46
    Aug 23, 2011
    Kansas City, MO
    Ram Year:
    2001
    Engine:
    5.9 (360ci) Magnum
    Yup mine does the same thing. I see it as an advantage tho lol. I can run out and start it up in the winter, pull the keys and lock it.
    Alex and NYCruiser like this.
  9. GotExhaust.com
    GotExhaust.com Preferred Vendor
    273
    88
    Oct 25, 2013
    Ram Year:
    Engine:
    I started my first car with a screwdriver. That thing was mint.
  10. jsl6v8
    591
    66
    Jan 31, 2013
    Ram Year:
    Engine:
    3.6L V6 And proud.
    You know when I first posted about tossing my keys I really didn't think about them being needed for the door still, boy did I feel really dumb when the next guy posted that.
    It is kinda nice, I do leave it running and pull the keys and lock the door all the time, but it still kinda bothers me, its just not suppose to work that way is all. Haven't decided what I'm going to do with it yet, its probably more than I want to spend to get it rekeyed and there is no way in hell I'm carrying around more keys.
Share This Page
