- Jan 8, 2015
- 9,102
- 4,793
- Location
- St. Louis
- 2014
- 3.6 Pentastar
OPT7 vs Hikari Ultra vs Hikari (Cheapest)
I changed these OPT7s out for Hikari Ultras because one of the LEDs burned out on the OPT7s. I also tried out the cheaper Hikari LEDs in a quad headlight just to see the difference in brightness. Here are the Bulbs used...
Original OPT7 (I paid $99.99 a few years ago).
OPT7 Fluxbeam H11 LED Headlight Bulbs w/Arc-Beam - 60w 7,000Lm 6K Cool White CREE Kit - 2 Yr Warranty https://www.amazon.com/dp/B00VNBDWPK/ref=cm_sw_r_cp_apa_i_0vFaCb0HC58GN
Hikari Ultra
HIKARI Ultra LED Headlight Bulbs Conversion Kit -H11 (H8,H9),Philips Lumileds 12000lm 6K Cool White,2 Yr Warranty https://www.amazon.com/dp/B077BT6M6Z/ref=cm_sw_r_cp_apa_i_DvFaCbK88NSJ0
Hikari (cheaper)
HIKARI LED Headlight Bulbs Conversion Kit-H11(H8,H9), 2019 New Gen of HIKARI, Adjustable Beam, 9600lm 6K Cool White,2 Yr Warranty https://www.amazon.com/dp/B07GKPR452/ref=cm_sw_r_cp_apa_i_uZEaCbZPF12AM
Pictures...
OPT7 (left) Hikari Ultra (right)
The Ultra has much less scatter and allows you to adjust the bulb alignment after it is seated and sealed in the housing. I would say it's about the same brightness but far less scattering of light.
Hikari cheaper (left) Hikari Ultra (right)
Only slightly dimmer using the Mark I Eyeball (I had to stare for a while to see the difference in output). Honestly if I wasn't planning on using the cheaper ones on my wife's fog lights I would have kept that in my truck for the cost to brightness ratio. The Hikari bulb's alignment adjustment really focuses the light in our quad reflectors as well.
Overall, the newer LED arrangements that more closely mimic the halogen filaments are a big improvement. I adjusted the headlights WAY back up after removing the OPT7 bulbs and haven't been flashed yet. I'll do a proper aiming using Headlight Revolution's How-To video tomorrow.
Edit: A very important piece I neglected to mention. The Hikari Ultras have an in-line driver and require an additional CANBUS adapter to turn on. If you don't order the adapter you can contact Hikari after ordering the headlights and they will send you a coupon (on Amazon) for 99% off making these $19.99 adapters essentially free (I paid $0.20 for the pair after the coupon).
Here are the adapters...
HIKARI Pair LED Conversion Kit Headlight Canbus Error Free Anti Flickering Resistor Decoder - H11 https://www.amazon.com/dp/B075CJZ9F2/ref=cm_sw_r_cp_apap_Zjgcye4osIG54
The cheaper Hikari lights (that are almost as good as the Ultras in my opinion) have no in-line driver and do not require the CANBUS adapter to work. In fact, they wouldn't even turn on when the CANBUS adapter was attached.
Finally, the Hikari Ultras removed the headlight out message I had with the OPT7 lights. I don't know if the same could be said with the cheaper Hikari bulb as I never had both of those installed.
Edit 2 (fog lights):
Ok, I got the 9006 bulbs on sale for $25 and I'm pretty happy. Note that I have yellow Lamin-X on the fogs, hence the color...
Unclocked...
Clocked (housing needs some aiming)...
Off...
On...
Note: If they don't light up flip the factory plug around and try again.
Hikari Ultra
Hikari (cheaper)
Pictures...
Unclocked...
Off...
On...
