Cableman
This one I have projector lights which it doesn't fit?
https://smile.amazon.com/dp/B07MNG5S5P/ref=cm_sw_r_cp_apa_glc_fabc_JG798QT02N6AV6BA8J91
Im not sure what your asking there.
So again.... What type of projector?
Without getting into the whole debate of how much better HID's are in the projector housings, has anyone had any success with an LED bulb? I know the LED's have come a long way and was looking at the Headlight Revolution V.4's. They are $297 but dont mind spending the money if there is a significant improvement in lighting.
Yes I know HID is the way to go however, I prefer a P&P solution and have no desire to start running wires for ballasts and drilling dust covers etc. Just wondering if anyone with the projector housing has gone with an LED bulb and is happy with it.
Did you still have to flash your vehicle for them to work properly?I have those bulbs in my 2011. The H13 version. Absolutely the best thing I ever put in it. Headlights sucked from day one till I put these in it.
Their customer service is top notch if you have a problem or warranty issue also.
Go for it you will love them
Brand?If you dont mind waiting a couple weeks to a month, get on Aliexpress and order led bulbs in the style you need. I got 8000 lumen bulbs with canbus built in for $30 shipped. They work great in the projectors and still have the factory cutoff that wont blind people. If the price was the same I think HIDs will give you a little better light, but if you can be patient LEDs can be super cheap. See attached photos with low and high beams.
View attachment 244213 View attachment 244214
Link?When I color matched mine I installed Diode Dynamics LED’s low and high beams as well as fogs, plug and play fit inside the stock housing. View media item 29181
After doing some research and based on the reply I received from DDM Tuning, I'll be going with the below:
For your low beam upgrade, you can use our Saber ProX 55W Accu/V2 9005 LED kit, which is proven to function perfectly on this application without requiring any additional decoders. Also, it won't have any fitment issue on your low beam upgrade. Here is the link:
https://ddmtuning.com/SaberLED-ProX-55W-Accu-V2-9005-W-Y
If you would like to upgrade your high beam too, you will need to use our Saber Pro V2 50W 9005 LED kit instead. This is because your high beam upgrade has a tighter space, and 50W V2 has a smaller bulb base for better fitment than 55W V2. Here is the link:
https://ddmtuning.com/Saber-50W-V2-9005-W-Y
(with 50W V2, you don't need to add any decoder neither)
Question why spend $400 + on above when you can get bulbs and OBD scanner $99 on Amazon for less?After doing some research and based on the reply I received from DDM Tuning, I'll be going with the below:
Brand?
How long installed?
Projector lights?
What don`t you like about having a fan on the light? Would it not help keep the light cool for longer life?Factory projectors
Just installed these low beams about a month ago: https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
I would consider a fanless one like this: https://www.aliexpress.com/item/100...earchweb0_0,searchweb201602_,searchweb201603_
I had zdatt low, high, and fogs for about 2 years. I just had a low beam go out due to the fan going bad and stopped working. They must be tied together somehow. I didnt see the fanless ones when I ordered the new pair or I might have ordered those.
I've had these in my truck for 8 months and love them. They are bright and white - which is exactly what I was looking for. Plug and Play and priced right. I have the projectors and did the high and low beams. I ended up doing the fog/driving lights too - so the colors would match. Its a HUGE difference having the fog/driving lights switched also.
BTW - I have had no issues with flickering.
https://www.amazon.com/gp/product/B07WCSJQYC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
What LED bulbs did you use for the test just for some additional clarification?View attachment 244360 View attachment 244361 View attachment 244362 View attachment 244363
Above is some testing I did with a small H11 Halogen projector low beam only in these pics. These tests are only good for my bulbs in my housings at the time of this test and not universal but it shows a big difference in beam and light output. The LED (top Image) has the foreground dead spot from the PCB board for the LED chips, light output is white and has a decent cutout however the intensity is much lower than the Halogen (below). This isn't an apples to apples comparison though as the Halogens in this pic is an H9 bulb (higher brightness than standard H11) but the H11 still performed better I think than the LED which had slightly higher LUX (not much) but the beam pattern of the H11 and H9 is much fuller and smoother. The pics show about a 300 LUX difference (H9s are brighter) which is a good amount of light being left on the table. HIDs in the same housing produce identical halogen beam pattern but 3-5x the LUX. My MAX LUX measurements are at hotspot only.
Ive done light output testing in a good bit of different setups with Lux readings and such. LED's can be a slightly upgrade in LUX over halogen with an increased life span but your going to be in the $200-300 range for the good stuff. HIDs are still better and cheaper for the most part especially with beam pattern and focused hot spot LUX. With that being said I swapped my wifes H11 CRV halogen projectors for Amazon LED bulbs 30w and the beam is meh (some foreground loss/funkiness) but I did can about 200lux at the hotspot. Her car is very sensitive to HID noise and causes the ECU to go bonkers making the car unsafe to drive. I've tested the LEDs in other projectors and in the low beam it performs much better than HIGH beam halogen projectors. So the LED might look/work better in a bixenon style Halogen projector on low beam but once High beam is engaged it will likely turn to poo.
