left turn signal light comes on with the headlights
jakefrancis127
got an 86 d250 that the left turn signal light in the dash lights up solid when i turn the headlights on. turn signals work normally...any ideas? thanks in advance
kad
Hudson Valley, NY
5.7L HEMI
I'd start checking the harness. It sounds like either there is a short between two wires (on a truck that old, possibly rodents gnawing the insulation off is highly likely) or a corroded connector causing the same short effect.
Edit: Wait, you said it's the light in dash... Possibly still corrosion or a short, but it's going to be much harder to get at if it's in the cluster.
-K
smithwessn
Yep, there's a short somewhere. You're going to have to do some detective work and physically track it down. Not necessarily difficult, but possibly time consuming. You may want to track down a wiring diagram to make life a little easier.
*edit* Use that wiring diagram to see what wires and connectors that light and the head lights have in common. And verify its only on with the headlights, or just the parking lights to narrow down your search.
jakefrancis127
jakefrancis127
didnt think about testing just the parking lights, ill try that when i get home.
jakefrancis127
jakefrancis127
Found the short in the short extension harness on the driver side turn signal. now the joy of finding one of those...appreciate yalls help
Reactions: kad
kad
Hudson Valley, NY
5.7L HEMI
Glad you found it. The short is not repairable? If not, at least you're in prime territory to be able to find a truck that old at a salvage yard.
-K
smithwessn
As stated above, repairing the wire is a very viable option.
jakefrancis127
jakefrancis127
Corrosion in the bulb socket caused a short, the short pigtail with the socket and the 3 pin connector are too damaged. Local parts house has the part minus the 3 pin connector. Time to bust out the weatherpack connectors
jakefrancis127
jakefrancis127
-K
Between the salty air and moron drivers, 1st gen dodge's are getting pretty rare down here
