running light stays on and flashes fast with hood
2000beast
Delaware
Cummins
My dash left turn signal started flashing fast. I figured that I must have blown a lamp but when I took a look the left running signal was on dim all the time even with the headlights off. When I turned on the left-hand turn signal the front lamp flashed on and off but fast along with the rear left signal. What complicated the problem was that when I opened up my hood to look at the wiring, I noticed that my hood light was flashing with the left-hand turn signal :oops: I know I need to dig into the wiring harness but I'm hoping that somebody had this problem and knows where the short is! Thanks All!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Some older vehicles signal lights flash rapidly when a bulb is out or the Flasher Unit is bad
Lowrider357
