Lift kit, leveling kit or body lift???
captjanes
hey guys new to the forum.. my friend has a 2010 sport 5.7L and he wants to run 35" tires.. what should he do? lift kit, leveling kit or body lift? i come from the jeep world and we dont like body lifts but im not sure about trucks.thanks in advanced
White Beauty
Moncton, NB
2011 Ram 1500 SLT
2.5inch front level. I have an 11 started out looking like the first pic.. running 35's
then I added a 3inch BL.
quietpeen
2021 TRX
Hellcat
if he is not going to offroad the truck body lifts look good on these trucks, and cost considerably less than suspension lifts
C
captjanes
he will not be doing any offroading.. so how high of a body lift needed to clear 35" tires? what is a good brand and where to buy with everything i need included
C
captjanes
so no one can recomend a brand and a hight to clear 35's?
White Beauty
Moncton, NB
2011 Ram 1500 SLT
2.5inch front level kit will clear 35's not sure on brands, as mine came from dodge leveled.
BL wouldnt be required to clear 35's as seen in the above "before" (left pic) of my truck
huff2462
Baltimore, MD
It's tough to answer. With the right backspacing, he could go as little as 2" with no rubbing.
Personally, I'd recommend a 3" body lift minimum... but it'd definitely look better with a level also... as you can see in the pics above.
(And he'd still be saving money over a suspension lift)
'13 RAM 1500 Big Horn, 5.7L Hemi, 8-sp trans, 4x4, 3.21 gears
C
captjanes
if he went with a 2.5" leveling kit is that hard on his ball joints and cv shafts??
huff2462
Baltimore, MD
Bodylifts should have no effect on suspension since its just raising the body off the frame... 2.5" level isn't too extreme; as long as you get a good install you'll likely be fine.
White Beauty
Moncton, NB
2011 Ram 1500 SLT
I have 60k on my truck.. bought with 30k and had level on it when i bought it... so far no issues.. BL is a lot harder install then doing a 2.5inch front spacer, and if you want it slightly higher add a 1 inch rear spacer. total install time, less then 1.5hrs for front and back.. BL to the unexperienced person will take 12+ hrs.. ask Argray he and a buddy did theres together in a driveway, took them the weekend to get both done.
My brother is a licenced mechanic with a lot off offroad install experience and got my BL on and dual exhaust cut and rewelded up to the proper height in 6 hrs.
C
captjanes
so if i instal a ready lift (2.5 front and 1 rear) they just have the blocks listed on the website. will i need longer shocks to or do i just install the blocks??
C
captjanes
i was lookign at the rough country sku: 359 leveling kit 2.5" front 1.75" rear.. i looked for this product in a few different places and they all say that the reccomended tire is 33x12.5?? i thought that a 2.5" leveling kit will clear 35"??
quietpeen
2021 TRX
Hellcat
with the right backspacing on the wheels you can fit 35's with the 2.5 level kit.
the kit you are looking at will not give you a level look if that is what you are looking for.
C
captjanes
so what is a kit at a reasonable price that will make her level?
also the owner was looking to run 35's on stock rims or maybe drop back to 17-18"
quietpeen
2021 TRX
Hellcat
if its 4 wheel drive get a hell bent steel 2.5" level kit (they are a vendor on here)
C
captjanes
So this will level her and fit 35" right?
If he goes with new rims should he get offset rims ??
quietpeen
2021 TRX
Hellcat
that will get it pretty close to level. You can get a little more lift with bilstein 5100 adjustables but they are more costly(don't know if money is an issue)
depending on the width of tires they could rub with the stock wheels. If he buys aftermarket a 9 inch wide wheel with zero offset would work well.
C
captjanes
Great thanks.. So if he goes 35" what would be the widest he can run With zero offset 9" rims? 12,12.5,13,14.5?
quietpeen
2021 TRX
Hellcat
12.5 would be the safest bet, possibly 13
