Working on my truck as we speak but doing alot more than just installing the brackets so it might take a bit.so, any feedback on these from people that have actually installed them?
From illicit customs:
ATTENTION:
All customers that have ordered either the cut or no cut 09-16 Dodge RAM Rear Correction Kits.! The passenger side bracket will need either drilled and tapped, or drilled with lock nut added; for passenger brake cable. Factory cable mount location is covered when installing new brackets, drill hole size large enough for bolt then add steel lock nut an torque.!(You can also follow tap & die parameters for the factory bolt size.!) If you have any questions feel free to message me on FB, through email([email protected]), or call me using button on FB.! Thank You and sorry for any inconvenience.
I'm going to wait on ordering for my truck. Looks like there hasn't been a long term testing on this product. Not going to fork over $500. I'm in no hurry, just wait awhile till the bugs are worked out.
Didnt get alot done this weekend weather man said it would be a bit warmer than it actually was. So next weekend is the next deadline for me got to get this thing done..
I'd like to see some pics yes sir. I will track down that Facebook page.Soward I ran into a little bit of an issue,nothing serious though. Ryan didn't allow for the bolt to bolt the e-brake cable back on after you trim the upper mount. I added a small 3/16" tab to the top of the passengers inside bracket. Tabs about 2" long and I drilled and tapped it for the factory 8mm X1.25 bolt. It moves the e-brake cable up above the arms instead of running it between the arms. I can post pic's over on the Ram R/T facebook site later if you want. I don't post pics here,to much of a pain in the rear to add a pic here,lol.I sent the pics to Ryan,hopefully he modifies the inside bracket to have the tab.
Rick
Sent from my SM-G935P using Tapatalk
newest no cut and cut ones will have the hole drill in them for the ebrake cable bolt
For the guys with the first gen of the Cut brackets from Ryan at Illicit,he's going to send out a bracket to re-mount the e-brake cable mount on the passenger side of the diff/truck. It's a bolt-on tab similar to what I made,but with more adjustability,and probably about 3 times the quality,lol. The tab will come with a longer bolt to mount it to the inside of the pass side upper link mount. You can still install the kits,but when you do,route the e-brake cable on top of the upper link bar,instead of in between the link bars like it it is from the factory.Then when you get the tab it's just a matter of swapping out the upper link mount bolt sliding in the longer bolt and slapping the tab on the inside bracket. The tab has 3 holes for mounting the e-brake mount to,so there's lots of adjustability, for mounting the cable back in place. He should have pics up on his site sometime later. He sent me pic's a little earlier,so i'm guessing in awhile he'll have them up.
