lockpick install
sweetstang
Well I just got my lock pic for my 11' sport CC. Any insight on the easiest way to get the dash apart to install this thing? I Will also be wiring up a headrest monitor.
Thanks
Brandon
blackout11
alpharetts GA
2011 R/T
What kind of consul do you have do you have the floor shifter they come off pretty easy but need to know which you have first
And a lock pic makes it so you can use your dvd or nav while your driving
S
sweetstang
I have the floor shifter.
blackout11
alpharetts GA
2011 R/T
Ok first remove that ring around your shifter you know the annoying chrome one just pull up on it be gentle it will come off. Then in the very front (bottom by the radio) theres a big storage area remove that rubber insert there are 2 Phillips screws in there. Now the bottom piece can come out ounce again pull on it its just clipped in. Ok the radio area you will see the plug on the dash for 115 remove the piece around that theres a torque screw there then on the top of your dash the tray that sats dodge theres a rubber matt in there remove that 2 more torque screws. Now thats ready to be removed be careful you have to disconnect all the wired behind the bezel to
S
sweetstang
Thanks for the help- I will keep you updated on the install
blackout11
alpharetts GA
2011 R/T
Hopefully these help
2 Philips screws down here
Remove the piece around this area theres a torque screw here
Its either a t-20 or t-15 torx screwdriver
LB3711
Trumbull, CT
3.6L V6
someone needs to post a How-to on dash removal
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
Great pics Walt! I'll need to refer to these later when the time comes to install my lockpick.
blackout11
alpharetts GA
2011 R/T
N/p have it out so much i can do it in my sleep some will say you need a trim removal tool but if your gentle stuff pops right off and also once you get that chrome ring out plasti dip that beacth or paint it.
I call it the chrome ring of blinding death
Picton
Houston, Texas
...also once you get that chrome ring out plasti dip that beacth or paint it.
Lol...of course, if you have the mopar T-shifters like we do the chrome ring of blinding death is no longer an issue.
blackout11
alpharetts GA
2011 R/T
Hence why i got a black billet r/t ball now grabbing that sucker in the summer that another issue
quietpeen
2021 TRX
Hellcat
good info walt.
I also wanted to add that the lockpic also allows you to hook up a backup camera, and the rca connections for the headrest monitors
