long tubes
the codes
Houston, Tx
Magnum 5.2
so I know long tubes delete the cats and that's illegal in texas but if I know a guy who will pass me...?
I know with the cat delete codes get thrown, isn't there a fix for this? I was trying to remember it the other day but just can't remember.
Tapatalk Addict
Badger
Bettendorf, IA
I don't think there is a way around it because you won't pass a visual inspection. Better move to a stat that don't care like Iowa :D
the codes
the codes
Houston, Tx
Magnum 5.2
haha right? of all the places you'd think texas would care less about smog haha
Tapatalk Addict
Badger
Bettendorf, IA
Farming states seem to care less because of tractors etc.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I've never had a truck visually inspected. As long as its not throwing an CELs and everything is stated as "ready" they don't care.
Badger
Bettendorf, IA
When I lived in new York I had to pass the computer inspection and a visual inspection.
BlackedOutHemi
DFW, Texas
2012 & 2012
Well, if he's in Texas, like me, then he shouldn't get a visual.
the codes
the codes
Houston, Tx
Magnum 5.2
im not as worried about the visual as I am the codes from not having the cat. I think there's a module that fixes it or something like that
Tapatalk Addict
BlackedOutHemi
DFW, Texas
2012 & 2012
the codes
the codes
Houston, Tx
Magnum 5.2
hmm yeah that sounds like what I need. I apparently have a short in my wiring that runs from the computer to the o2 sensor harness. guess I'll have to get that figured out before trying to get rid of the cat. *sigh*
Tapatalk Addict
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Long tube headers just mean you have to move cat. You could still use one if you wanted and the sensor. This means you need to put the cat as close to headers as you can, and use header wrap or ceramic header coating to keep heat in pipes.
But in Missouri it dose go by county because I live in Franklin with emmissions and just 2 miles away in Warren they only have safty.
the codes
the codes
Houston, Tx
Magnum 5.2
is there a benefit to deleting the cat?
Tapatalk Addict
DOAX
and on the topic of headers
at what point do the stock manifolds on the 5.2 and 5.9 actully become restrictive
the codes
the codes
Houston, Tx
Magnum 5.2
better flow thats about it and you kill more birds
haha like that answer. considering the extra performance doesn't make you have more of a lead foot, what about mpg?
Tapatalk Addict
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
O2 Simm - The Fastman
this is where i got my throttle body from also. i am gonna use these in the future, when i finally switch my exhaust around again.
BlackedOutHemi
DFW, Texas
2012 & 2012
maybe its based off county...in Houston I kept failing inspection because of my 02 sensors?
If your O2 sensors are not ready, or are malfunctioning, you will fail the test. That is through the OBDII port though. Which is computer related only. If you have an emissions check, they toss a tester on your tailpipe and check it like that, and then visually inspect it.
