Lowered inner fenders?
audio ram
What is everyone using for inner fenders when lowered 4/6 or 5/7? I am on my 3rd set. My current set up is IHC front with stock springs and Viking double adjustable shocks.
I think guys are leaving them out when they get that low. If you have 3 sets to work with,have you considered trying to cut them up and modding one set yourself.You should be able to make one set out of 3 that'd work with some heat and maybe a bit of plastic welding or riveting.I've never seen a set of aftermarket liners that are strictly made for a lowered Ram,but that's not to say there aren't any though.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
What size tires you running? I'm in the process of going from 285/45/22 to either
285/35/22 or 295/35/22. Probably Toyo proxy or something similar
I'm 4/6.
A
audio ram
I am on 285/35/22 on the front
Bigskyroadglide
What shocks are you running? How is your alignment?
I am running bilstein 5125s and only occasionally rub at high speed on big dips.
I had front wheels off today and my passenger inner has minimal rub marks whereas the driver inner clearly has a large tire mark. In looking at my alignment sheet, caster is clearly more positive than I would like on the driver's side. I'm thinking I need to have some more negative caster on the driver's side which will require me to adjust the upper control arm a bit inward.
My 285 35 22 tires are on the way, and I suspect once installed with a bit more negative caster on the drivers side I will not rub.
I will let you know if these minor adjustments work but it's almost perfect. It's the only issue I'm currently experiencing with the kit.
I'm a RCSB, RWD. Could be different than your quad cab.
PS, is that the factory front ground effect or aftermarket?
