razor1
- Joined
- Dec 27, 2015
- Posts
- 429
- Reaction score
- 208
- Location
- St.Petersburg Fl
- Ram Year
- 2018
- Engine
- Hemi 5.7
Just a little information for everyone with my experience on lowering my 2016 RT. I use the Belltech 2/4 drop kit with springs, pan hard bar relocation , street performance shocks and sway bar link ends. Something I found nobody says about lowering the trucks is that after you lower the vehicle the rear end is 1 inch forward and not centered in the wheel well. Another bit of information I could not find prior to doing this is that once you lower it and the actual moves In order to fix it you need to replace both upper and lower rear control arms. this allows you to adjust the pinion angle and to push the axle back 1 inch. the arms are used in the back were Spohn adjustable arms. All totaled out to $1,100 for the drop. that does not include an adjustable pan hard bar at $200 should you need to center the axle. I personally have always had sport trucks so I can justify the cost making the truck what I want it. Some people might just be looking for the drop look, but there is much more involved to make it correct.
