Maintenance Parts Install and Cam # 5
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
This is an 03 specific thread Really. Truck needs work and I've been so Busy Completing the Mods on my Magnum that the Trucks Maintenance and wear plus failure of some parts is long overdue. Hope in the next week to get some things done and will report the progress and hope to throw up some pics. Nothing fancy and low budget.
This is what i have waiting as far as parts go.
Backing plate assy complete drivers side.
Rotors and pads Rear.
80/90 Gear Oil and Ford friction modifier.
OEM New trans pan, spin on and cartridge filter.
Mopar Trans RTV, new OEM bolts and 8l of ATF + 4.
Pacesetter Longtubes, Off Road Pipe kit.
02 Extenders BBK (back ordered)
Spare 02 sensors (1 fwd/1 aft)
6.1 header bolts and OEM gaskets
Antifoulers kit
18MM Plug kit (ordered)
RE-use current Magniflow HF Cat
Used Valve Rails (48k miles from my spare LX Crazy Spartan Motor 2 x Int, 2 x exh)
6.1 Intake and exhaust push rods (used 8k miles)
Oem crank and Cam Bolt
8l Long Life Mopar A/F
Taylor Shorties (Red)
Black Valve Covers (03-05) Painted from Last Motor Swap on the Magnum (went Mopar Chrome on that Motor).
Oil x 7L Shell Dyno Oil 5w30 and Lucas Stabilizer, Hastings Long LF 115 Filter
16 Copper Spark Plugs (to be sourced next week)
Oh and Comp Cams 260 (Enroute)
Also need to replace or Bedline coat the Rear Bumper and Repaint the Trailer Hitch Area.
Danny
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Stripped the paint off the headers and applied 1st coat of POR15 manifold paint. 24 hrs i can give it a second coat then another 24 hours until i can install them and heat them up to cure the paint. I opted for this as i could not afford the ceramic upgrade. Small half quart of this paint was $44 bucks. I have seen it used before and is an awesome heat paint.
Tommorrow I will remove the old exhaust system and hopefully the cam will arrive by Weds.
Will add pics when i get this going. Danny
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Excellent! a 03 thread...
Danny, the LT's have a O2s **** in each collector. I use the passenger side **** for the forward O2s and the driver's side for the wide band. Are you going to stay with a single cat? If not then I'd recommend adding another **** on the ORY cross over pipe. I don't know if there is room on a 4x4, but on a 2wd running 2 cats fits great. If you have the spare trans pan already it's easy to add another O2s **** to the new pan for a drain. Again a O2s "plug" can also be used for the oil plug. I did this on my differential cover. Looking forward to see all this getting done.
ST-8
Doesn't your truck already have a cam in it Danny?
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Greg, gonna re install the magnaflow HF Cat for now. Good ideas on the wideband and drainplug idea. I also have a sensor for a trans fluid temp guage and pillar pod i got way back from Aaron but not sure were the service port for that is on the trans. Will look when i crawl underneath. Also need to fix the shifter cable fo the B&M floor shifter as i lost 1st gear.
Mario, current Cam is the Mopar Performance drop in. Was gonna go Crazy Jay plus but could not find a tuner and the DSP on an 03 is problamatic, anyhow the Mopar Cam is nice and comes on hard but only after 3 k. Option two was the 6.1 again with 6 degrees advance but the timing chain i wanted was backordered and i have already run that cam twice. My goal is more torque for towing my trailer so i am going with the comp 260 which should work good with my 2600 stall and 4.56's. If idling becomes an issue i will borrow Gregs idle up mod info and or employ the PSC -1 i also got from Greg a while back so may need your input on that buds. I am confident the 0-60 will get me close to mid fives with the LT,s/Cam combo and supporting mods. Danny
Redtruck-VA
Virginia
I'm not sure about a port on the trans for a temp gage. I've seen where folks have used an adaptor with a sensor to the cooler and I've seen bungs welded to the oil pan. IMO the most accurate would be to read the cooling line going to the trans cooler. I use a AeroForce gauge that reads off of the OBDII port. Welding a drain and sensor **** on to the pan seems a easy solution.
ST-8
Nice combo Danny til this past weekend I was running a very similar setup- 260/2600/4.56s an lts on just superchips. Now it's diablo tuned an switched the 2600 for a billet 3200 circle d
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Nice! Yep thats the Idea on the Superchips. Headers are ready to go, found a **** plug for the drivers side header. Cam came in late yesterday, gonna go pick that up in town. Not a copper plug to be found anywhere "Chevy Town I live In" so i had to go with the Champion Platinum which is what is in there now but Gap is knocked down to. 40 thou so i'll throw them in for whoever buys the Mopar Cam from me. I run the platinums in the Magnum. Have found that the Gap stays more to spec than the Coppers when it comes time to change them at the 30k intervals and that alone justifies the upgrade. Iridium on the other hand is a waste of $$ and they get melted faster and only last about 20 k miles in our Motors (1 range colder anyhow)
Redtruck-VA
Virginia
Danny, how about NGK 5306 or one step colder NGK 4306. I use the 4306 gapped at .040.
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Those are good plugs Greg. I got standard heat range and will leave/ check them for 44 (tbc).
I have Cam in hand. Will get this going tommorrow and finally upload some pics to PB. Danny
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Update: Been Busy with Daughter/Son in law/ Grandaughter moving back home (Military Posting to the Base Where I work at) so Truck was needed last couple days to haul her stuff out of my place.....yes! Managed to install the exhaust headers, off road mid pipe. Because my Catback was custom fit the pacesetter pipe to tie that in was axfew inches short. Anyhow they don,t give you a rear O2 port so had the muffler shop do that and at same time some welding and a new Pro Flow stainless muffler onto existing custom fabbed taillpipes tgat where in good shape. Truck sounds great and not too loud but just as rumbly on the HWY compared to the shorties HD muffler i had before. No drone and this new muffler is not a straight thru and IMO along eith the y-pipe junction provides backpressure. Zero rear sensor Codes (Cels). Will post up pic of that solution (Cat is Gone) along with todays work which is when i got going again. New Cam is in so i'm half way there. Been taking pics and with narrate a short Cam refresher for the 3rd Gen guys thinking of Camming. Note it makes a big job easier when the appropriate upgraded valve springs are already in place. Will fix spelling after. Danny
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
OK a couple pics during the intermission while we wait!!!
03MopaRamman
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Thanks Aaron the Pacesetter are from past inspiration of a certain Black 03....lol. So the Cam is done, no issued what so ever. Valvetrain is real quiet with the new rails and rods. So i let it learn the idle (PCM) until the coolant was ok and air all out (had to crack the t-stat housing momentarily and blow in the resevoir (03 thing) then idle in drive then drove around the village for 10 minutes and hit the hwy. I liked how it accelerated so i turned around to my favorite spot and decided to do a 0-60 just to see in drive not even bothering with the OD off. Well had to abort because all i did was seriously smoke out the 285 duratracs and leave two black marks 50-60 feet long on the road. So i look down and laugh when i see the Superchips logged it anyways, 0-40 in. 85 and 0-60 in 1.37 sec.....haularious... Gonna change the Oil then run to town for cigars. Will upload pics this evening. Still have the trans service and rear brake work to do but am very very pleased the Ol girl is a real sleeper Again. Danny
