Mevotech install question!!!
zstampe
I'm about to install my new MevoTech UCA's on my 2015 CCSB. I have a pickle fork to seperate the ball joints but i'm not sure it will work. The space between the spindle and UCA looks too wide for the fork I have. What did you guys do? Any advice would be appreciated.
Zach
:superhack:
Hemi395
Cape Cod MA
Zach
:superhack:
When I leveled my truck, the ball joint almost separated on its own. I tapped the knuckle with a hammer and it basically fell out.
If you try that be gentle with the knuckle, I've heard they crack easy...
zstampe
zstampe
When I did my leveling kit I tried to do that with no such luck, that's why I didn't replace the UCA's at that time. Now I have some time to mess with it some. Thanks for the advice.
I used a pickle fork and then it popped out.
Ok, I will try the pickle fork I have. I just don't know if it's big enough. I thought about getting one of the mechanical spreader type they sell at Harbor Freight as well. I know HF tools are usually junk but for a one time deal it should be ok.
EDIT: I am also getting some front end noise now when I hit bumps. I hope it's the ball joints since I already have the Mevo Techs painted and read to go, and not something else.
Zach
:superhack:
Hemi395
Cape Cod MA
I'd definitely use the fork then. I didn't want to use a fork because there's a good chance of it tearing the ball joint boot. Sounds like I got lucky with mine.
The good thing is if you mess up the ball joint boot on the stock UCA it doesn't matter because you're replacing it anyway.
Kinda wish I'd done the Mevotechs...
bigolayne
Springfield, MA
Did you switch to Bils as well or already?
R.L.K.
Bristol , Tn.
When I installed my bills & Mevotecs I smaked it 3 times with a large ballpoint Hamer and the fell apart .
Go to you tube and search " how to install a lift kit " it shows how to install the Bilsteins which includes the uca Balljoint separation .
I posted this video a couple times in 4th gen DIY .
Watch this video , it's a big help if you don't normally do this sort of work.
EDIT EDIT ^^^^^ EDIT EDIT ^^^^^^
GO TO 4TH GEN DIY AND SEARCH ( How to install a lift kit )
Look for this post
Hope this helps !
zstampe
zstampe
Look for this post
Hope this helps !
Smacked the crap out of mine last time when I did my leveling kit......no such luck. I'm going to try this Sunday when I do the UCA's. Thanks for the info.
zstampe
zstampe
Using my 2" spacers still. Might do the bils later. I'm ok with the ride as is.
bigolayne
Springfield, MA
The reason I asked was due to when I did mine there were some noises when I went over any bump. I asked the forum and someone said to make sure the Bils were tightened enough. I tightened down more and all noises were gone and the ride was tighter and felt great...
Make sure you check everything when done and snug again after driving some. And, alignment is a must
R.L.K.
Bristol , Tn.
I've heard somewhere on the form that if your hearing a bump noise it may also be due to installing the flat washer provided with the bills in the wrong location .
This flat washer DOES NOT go under the top nut , it goes on the shocks piston next to the Pistons (flange ) just below the threads up top then you install the upper spring seat assy then the top retaining nut with no washer under the nut
^^^^ Edit Edit ^^^^ sorry should have read my own post !
zstampe
zstampe
I was wondering about that. When I have the suspension apart for my UCA's I'll check that as well. I also got this in the mail last night........
xrsman
Ontario
3.0 Ecodiesel
Are sure you paint the Mevotechs before you install them. Otherwise they'll become rust city.
I used 2 coats of primer, 2 coats of black paint, 2 coats of clear coat.
Sent from my SM-G920W8 using Tapatalk
R.L.K.
Bristol , Tn.
Definitely paint them ! I used VHT Chassis paint , multiple coats.
zstampe
zstampe
Good lookin out guys, I painted the crap out of them with VHT engine enamel. They're painted and ready to go in. Just gotta find the time to do it.
zstampe
zstampe
Here's my truck too
zstampe
zstampe
Nice rig bro. You will definitely be happy with your new setup
Thanks bro, love this truck so far. First Ram I've had too. Had a couple fords and a Silverado that was junk.
bigolayne
Springfield, MA
This is my first Ram as well. I had Toyotas and then went to a Titan and then Frontier. I have been very happy and pleased with my purchase. With everything there are things I would love to change but this engine and transmission and the beast appearance make this the best thing out there.
The forum is a great place to get information and ideas from as well as having a good laugh too, ThatDude596...lol
