The dealer swapped my GY's out to Michelin's due to out of round issues.... what a difference, super traction improvement. I'll buy them again when these wear out!
Which Micheline ? ThanksThe dealer swapped my GY's out to Michelin's due to out of round issues.... what a difference, super traction improvement. I'll buy them again when these wear out!
It depends on what you’re looking at. They are comparing two highway tires. My Yokohama winter tires hold up with Michelin and Bridgestone and cost way less. If you’re looking for an off road tire other brands are better.Are michelins really that superior over other brands?
you know the saying 'your mileage may vary'? Well...
My prior truck, 2005 F-250 came with a brand new set of Michelin A/T2's when I bought it. Older couple used it to tow their 5th wheel and had very recently replaced the tires. I noticed quickly they were very quiet on the road, and comfortable on the highway. They also wore very well, and would have lasted (tread depth) well past the 60 month suggested replacement. But...
They turned every boat ramp into a nightmare. They could barely get the truck up my driveway in rain, much less snow. They were easily the WORST tire I have ever had, because for my driving and environment, they were flat out dangerous. I ended up with commercial yokohama ATM's and they were amazing.
If I lived somewhere without winter, and did not pull a boat regularly up mossy ramps, I would probably be the entire drum section of the Michelin bandwagon...but I doubt I will ever even try their products again.
If you have a 4x4 and your spending that much on tires you should get a BFG K/O or a cheap set of ten ply mud tires that are similar to the stock size. I usually spend $600 to $700 on a set and get about 50,000 miles from them. I spend 95% of my time on paved road and have no issues running M/T’s.
Thanks for the feedback and another way of looking at it.
How is the noise from the BFG K/O’s? Seems knobbier tire would have more road noise. But I have never owned a set.
I always get the 10ply tire for towing.
