Mirror w/mic wiring?
magician
Anyone have a good number for Uconnect wire harness for the mirror with the microphone? I have a mirror but can't find the harness that plugs into the module on the passenger side behind the dash.
Ricks Ram
PN....P68207372AB.....the last two letters might not be the same. They change over time but the part number won't change. If the numbers match it is the same.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Rick took care of ya.
If you need any install notes see the mirror instruction sheet I threw together from the 8.4 (RA4) conversion thread..
Quick Instruction Sheet References:
- 2013-2016 8.4 Conversion for 7 Speed Fan Trucks 9-8-16.pdf
- 2013-2016 Ram Radio Removal 6-27-16.pdf
- 2013-2016 Ram RearView Mirror (w/mics) Upgrade & Harness install 7-8-16.pdf
Optional parts
- 911/Assist AutoDimming Mirror: - 68096091AF
. . . or RA2 style Manual Dim Mirror w/mics: - 68102484AA
. . . (Mirror Mount Covers if Needed: Upper - 1ZA38DX9AA and Lower - 1YW11DX9AA )
- Mirror Header harness: - 68207372AB
- Antenna Cable Body Cell & SDARS "QUAD/CREW": - 68148279AD
- Antenna Jumper Cable: - 68148258AD
- Shark Fin Antenna: - 5091278AC
- SD Card Media Hub: - 68096428AD
magician
magician
Perfect, thanks to both of you guys.
