Texas Hemi
The looks good. Just out of curiosity, the BDS website says that lift can fit 37" tires. Could you have squeezed a little more rubber under there?
Updated Photos.
Added Flares and a set of Piaa LED fogs.
Oh and some MUD
You could go that route, or if you only want the leveling shock without the spring and all that, you can go with Bilstein 5100s. A little cheaper as it is only a leveling shock vs the entire strut assembly that Rancho offers. It will eliminate the small rake you have.So I was wondering what you guys think about getting a couple more inches of lift on my ttruck. I'm looking at these http://www.amazon.com/Rancho-RS9999...00|2760&Year=2008|2008&carId=001&n=15684181&s
Not sure what all options there are. Let me know if you guys have any ideas. Thanks
Not hard at all. It's basically removing and installing the front shock. Remove strut assy from vehicle. Compress spring, undo top nut, remove shock from spring. Adjust the spring seat ring to your desired height on the bilstein, insert into spring, install top nut, undo the compression on the spring, install into vehicle.How hard are the Bilstein 5100s to install?
Thanks
