WhiteExpress
- Joined
- Sep 8, 2011
- Posts
- 18,185
- Reaction score
- 3,276
- Location
- Midland, TX
- Ram Year
- 2004
- Engine
- 5.7 Hemi
That's a great looking bumper!
More pics please
Can you post some side shots please?
when I get the chance I’ll get some side shots. It hangs of about an inch per side which is a bit more than I was hoping but it doesn’t look as bulky as a lot of the other bumpers do. Plus my tires are out about an inch out so it looks good on my truck[/QUOTE said:How much hangs out the side after you put the fender flares back on?
Everything is adjusted and tight. Had to use a spacer on the bottom frame mounting point to adjust the bumper because it sat slightly tilted forward. Also bought 1/2” grade 8 hardware instead of the painted metric bolts. Fit is about 99% just the corner behind the headlight but that’s only a 1/4” space and I can live with that. That’s due to the spacers I installed. I love how open it is. This thing feels solid.
Depends on how bad I beat the stock rear bumper up. May do structural reinforcements inside the stock bumper and get it bed linered. If I do swap I’m looking at the fab fours rear bumper but it’s priceyi love that low pro look. What I dislike about some bumpers is how far they stick out. and this one give you that extra clearance too.
Perfect look for the 4th gen. I think you nailed it.
Matching rear in the plans?
