Need a better dome light LED..
DatacomGuy
Tampa, FL
Installed a festoon LED bulb in my express dome light, but its not nearly as bright as other's i've seen post on here.
What one did you buy, and any pics and links? I might have gotten something too cheap - need something significantly brighter.
I can take pics of mine later..
LB3711
Trumbull, CT
3.6L V6
stupid question is it facing the right way? Mine is pretty bright. Lights up everything inside better than OEM.
bskl76
Bako, ca
5.7 liter Hemi
Dome led
Hey buddy, I'm using 42mm 5730 9 bulb led. A lot brighter than older chips. It's a newer size led chip most are 5050 smd. Got extra 1 u pay shipping & it's urs.
SIhemi
Pennslvanvia
My first set of LEDs were that bright. I really don't need that bright of light that's y I switched to blue
DatacomGuy
DatacomGuy
Tampa, FL
Thats exactly the look i need. Link to the one you bought?
Positive its turned the right way, i think i just cheaped out.
LB3711
Trumbull, CT
3.6L V6
Perfect.. Thank you!
although on the last page I think someone with a 2013 I think has a electronic dome light which might be different than my standard run of the mill dome. LEDs might be different setup
DatacomGuy
DatacomGuy
Tampa, FL
I don't know anything about that. Mine isn't electronic, its a standard festoon like your rear dome.
Sweetee
Wisconsin
2017 Ram Laramie CC 4x4
3.6 Pentastar
I can take pics of mine later..[/QUO
This should create as much light as you'd ever need. I purchased this on Amazon (Amazon.com: Cutequeen Trading 2PCS White 5050 48SMD 48-SMD LED Panel Dome Light Lamp + T10 BA9S Festoon Adapter (pack of 2): Automotive) and wired them "in parallel."
96 LEDs should fit the bill.
DatacomGuy
DatacomGuy
Tampa, FL
Holy ****...
Sweetee
Wisconsin
3.6 Pentastar
I don't need sunglasses, but can read with comfort in the dark!
