Need Advice with 2011 2500 4x4
Redlinefab
6.7 Cummings
Looking for some suggestions and pic's. I have a 2011 2500 4x4 with a 6.7 / 6 speed manual. I want to change the stock tires to something taller and really not sure of what size I need to go with, the truck is stock. I do use this truck to pull trailers so I'm really not looking to add a 6" lift kit. Just a level kit. Thanks for all of the suggestions.
Stangshcky12
Oshkosh, WI
5.9 Cummins
What cab and bed do you have
A 285/70/17 fits no problem and fills out the wheel well pretty well although they still look small IMO on long wheel base trucks
A 315/70/17 fits but you will have rubbing in the control at full lock which gets annoying when backing up a trailer
R
Redlinefab
6.7 Cummings
Thanks for the information, I wonder if the 305's would rub?
Thanks again for the info as I'm sure this question has been asked. New to the forum.
Thanks again.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I'm not sure 305, I want to say they will
They aren't very common since they're a pricey tire
You could try to find something in a 285/75/17
It's about 34" and 10.5" wide
Thor09
Northern PA
The 285/75-17 is what I was thinking too
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
305/70/17's wont rub the fender, but they might barely touch the control arms at full lock. I am running these on my 08 3500, and that is the case with that truck. My 3" lift is coming off in a few weeks, and I will be going with the 305/70/17's on my stock suspension.
