NEED HELP - Amp and Sub settings...
aks0605
even though the OP solved his problem after reading the thread thought I would add this, anytime you wire in an output converter if you don't get any playback then check to make sure your output converter does not require to be programed also most line output converters will have a gain control on the module that could prevent playback. Just an extra trouble shoot that falls under the problems the OP was having
JustinRam1500
