Need help!!
croehm
Greendale Indiana
I have a 2011 dodge 1500 5.7 bighorn, I was driving it an all of a sudden it just shut off an coasted to a stop. Now all it does is crank.
Here's everything I've changed or checked
Plugs
New fuel pump
New cam an crank shift position sensor
1 New coil.
I'm getting spark, fuel, air but still nothing. Won't even start with starting fluid. I'm lost now. I have know clue unless it's electrical.
Any ideas would be greatly appreciated.
Black-Wolf
North Carolina
Are you getting any Diagnostic Trouble Codes? Timing might be off since you put in a new cam. You'll need to get to TDC on the #1 piston, check and adjust the timing correctly. Could also be either water in fuel or in the engine. W/O tearing down the engine (at least the top end) and verifying your timing, it's going to difficult to resolve.
