New and need a little hand
Dylan standalone
Fort st john
Hey guys new here and I got a little problem ...
So I have a 1991 dodge w250 power wagon and my outer axel shaft spun itself in half ..literally , I bought a new spindle hub and axle shafts but no one in my town can find the bearings and everything in between I need without proper terminology I'm gonna put manual locking hubs from warn on it as well so I know I need the spindle nut kit to swap over . I always not sure how to tell if it's a dana 44 or 60. The rear is a Spicer 6 it says under the hood so does that mean it's a dana 60 ?
Any help is greatly appreciated thanks. :)
crazzywolfie
under the truck
does it have king pins or ball joints? if it has ball joints pretty sure it should be a dana 44 and if it has the king pin setup i am pretty sure it should be a dana 60. you can try getting a build sheat running the vin. they can be hit and miss for info but usually have most of the info correct.
https://www.dodge.com/webselfservice/dodge/index.html
