6" Superlift. Go to auto accessories garage. They have coupons all the time. I got mine at Jegs because they had in stock and they price match. Paid $1177
http://www.autoaccessoriesgarage.com/
20x10 -12 LRG Sandman
35 x 12.50 Cooper ST Maxx
I just installed mine last weekend so here are some things I learned.
There are two different sets of instructions floating around for two different versions of the 6" superlift. I got the wrong instructions for mine but found the right one online.
If you do bilsteins don't screw up and put the washer under the nut like I did. It goes on the shaft first!
You will need a really short 13/16 open end wrench to get back shocks off. I cut one off at about 3".
When you first lower it to the ground dont freak out if one tire is pointing straight and the other is toed in like crazy. Also dont even try to measure the height difference until you back up and cut the wheels a few times. Scared the hell out of me since it measured 10" higher when i first lowered it down.
Will be glad to help with any other questions if you need it.
