Ok, I got it working. After the hub replace, I lost the TPMS sensors, and the truck would die after a couple seconds. Cleared all faults, performed hub replace again, and truck ran fine. Still no TPMS. Had to perform the sensor rolls test in the RF Hub menu while driving, and now all is good. A few things, though: to program the fob, I had to use my original truck PIN, but to reset the new hub, I had to use 0000. This remains the same now that everything is working, too. To program a fob, I’ve got to use the truck’s PIN, and to update the hub (after a TPMS threshold change) I’ve got to use 0000. One other thing, fobik safe isn’t working for me right now, so I CAN lock the fob in the truck. I don’t have the door handles installed yet, and I’m not sure if that has anything to do with it.
@skuppy069, did is fobik safe enable working for you now, and did you notice if it did before you installed your handles?
@mjf6175, I remember you went through this also, any thoughts?
All push button start prompts and proximity prompts are displaying on the EVIC as they should.
