OEM subsonic filter.
Masterglitch97
Has anyone ever tried to bypass the oem subsonic filter. On the 2016 dodge rams with the 3.0 I connect. Or even better. Know where I can pull the sub channel from. FYI. My truck doesn't have the alpine system so no stuck sub. Just hoping maybe the wiring is till behind the dash
naumaa1
Colorado
I know my front door speakers were full range, non-alpine system. Hope that helps
M
Masterglitch97
I'm using an lc7i to take input from the front and rear channels. However. After about 35/38hz. The output on the lower frequencies drops off horribly fast. By the time I hit my box tuning of 30hz or lower such as 25/23. There's no signal left and I get almost no sound. Was hoping that maybe the factory sub output would still be at the radio and I can tap into that
baum
savage, mn
2015 Laramie
in your case for what you want to do you should look int a true DSP unit that has the ability to flatten all out then you can adjust from there.
naumaa1
Colorado
I went with an audison bit one and it works great for me, if you just want bass restoration you could save a few bucks and go with an audiocontrol epicenter
M
Masterglitch97
I have experience with the epicenter. They are nothing but pure distortion to a system. I have both the dd1 and cc1 to tune my systems. Also With a DC audio 5k at .5ohms. Im not looking to clip. I will look into the Audison Bit 1 however if the stock headunit still isnt sending out the subsonic freq. How is the audison supposed to use what it doesnt have
Orca
