Sorry I can't travel into the future to talk about my decades old Ram but it's 5 years old on 5w20 with no start up noise.
If 30w is "better" in our engines designed after 2000 why would it not be equally "better" in some old Ford motor designed when Reagan was an actor?
Exactly. Don’t baby these Hemi. They last longer when you run them hard.I just did the first oil change on my 1500 with the 5.7...its a 2018, but was still new on the lot with 27 miles on it when I bought it this past December.
I'm not sure what oil they have in them from the factory, other than it being 5w20....but I had the dealer put Pennzoil Platinum 5w20 in for the change.
I never considered the engine noisy even on the factory oil, but I did notice it was quieter on Platinum 5w20.
I asked for Ultra Platinum 5w20....but that's not an oil the dealer has on hand.
Did some research on the difference between Ultra Platinum and Platinum.....VERY, VERY little difference...its mostly just more cleaning additives in Ultra.
In the end.... there's not enough difference between 5w20 and 5w30 to amount to much... and an oil a little too thick is just as bad as one a little too thin.
I'd be willing to bet millions of 5.7's never see anything other than the standard oil that dealers are directed by FCA to put in them... and the vast majority of them turn out just fine on that oil... they wouldn't be selling like hotcakes if that were not true.
I'm well aware that there are lifter failures, but I'm not convinced any oil within the required spec will make a difference on that in the end.
A little lifter chatter at startup doesn't necessarily spell doom...I know of one that's had startup tick since it was new....237,000 miles now....my uncle's truck, its never had any special oil, just whatever the dealer puts in it.... another, my brother in laws truck.... 183,000 miles, ticks about 3 seconds nearly every time its started, always has.... those 2 trucks are the reason I bought a Ram this time, never owned a Mopar of any kind before this.
Mine ticks about 3 seconds it once in a while at startup, but usually not.
Sent from my SM-T827V using Tapatalk
Hemi ticks and lubrication likely helps. All I’m saying though, is if you run the Hemi hard they seem to last longer. Likely cause the cams and lifters are getting lubed at higher rpm. If your are idling for long time or baby it, the lower rpm seems to be the killin the cam and lifters. Right lub and hard driving will favor the Hemi.If your hemi is ticking, it is a great thing that uoa's exist and are so cheap. Go get a uoa and see if the ticking is causing excessive wear or not. Since we have proven we can kill ticks with lubrication at a high success rate, it is worth a uoa to find out. if your uoa has less than 40ppm iron and copper, let it tick and have more confidence.
If the iron is way over 100ppm and high chromium, try our lubrication strategy or be prepared to replace that cam at some point. We have heard those stories about 300k mile ticking hemis and no issues, but those are unicorns compared to how many cams fail. If your engine ticks and you think that is normal, I have nothing else for ya, but good luck with all sincerity.
