Ok I need some help ... yes me go figure
ramhunter9
P-Star Jeep Wrangler
As you all may know I dont really drive my truck much , but this winter I have more than most .
I have a issue I cant track down and need some input .
For some reason my truck likes to eat battery's .
Here is the skinny .. thought I had a bad battery , took it in for a test it was low reading 11 volts not 12 . But after a our on the charger is tested 100%
So I thought the alt was bad ... had it tested .. 100%
So I did a code scan .. got Battery Low Voltage ... duh
Lost com with radio .. probably because im not running stock
And this one ? Condenser fan control circuit open ? Now I looked and traced everything does this dam thing have a relay ? Pulled all the fuses in the box all were good except the cig lighter .
I have no idea what is killing my battery .
If you have anything to add that would be awesome
The code for the fan was B10CO
onebadbee
do you have something plugged into the power outlet in the cab
ramhunter9
ramhunter9
I have been Google'ing no sign of a condenser fan relay ...WTF ?
ramhunter9
ramhunter9
Yes ... all aftermarket and are working as should .
It has to be something to do with the condenser fan control circuit open code
Everything else is fine
ramhunter9
ramhunter9
Fan kicks on and off like it should ?
ramhunter9
ramhunter9
Im not getting that code anymore after I cleared all codes .
ramhunter9
ramhunter9
went for a drive only code I got was the radio one
Now the battery was charged to 100% but now is at 60% And this was driving
ramhunter9
ramhunter9
Alt tests at 138 amps battery at 60% now
garner
Harker Heights, TX
Something is drawing. Check your fuses when the truck is off to see which one it is
ramhunter9
ramhunter9
Already did
It has to be a bad battery not holding charge . Reason ... the alt is powering like it should on the tester .
Charge the battery 100 % then start it and drive ... the entire time the alt is pushing 138+ amps to the battery . Get home test the battery its down to 60%
Bad cell I dunno , but im getting another battery
garner
Harker Heights, TX
Already did
That's probably it. My optima did that in my firebird would be at 12-13 volts and by the time I got to the parts store it was at 8, turned out to be a bad battery
ramhunter9
ramhunter9
12-13 volts ? wow didnt know a 12v battery could over exceed ..lol
I get ya ..lol
adamwilkes14
If the battery was only at 12v then it was not fully charged...it was only around 25%...a 100% charged battery should read at 12.7 volts...
ramhunter9
ramhunter9
I think Its the battery. Has to be.
adamwilkes14
Just hope you didnt hurt your alternator at all with it trying to maintain a bad battery. A bad battery last December cost me a new alternator on my 318.
