Pedal Commander Eng Error
RoadKing
Ga
2022 Bighorn
HEMI 5.7
I have had my pedal commander a few weeks. Really like it. But today i got a service electronic throttle message.
I stopped the truck and turned it off and back on and the message went away and then the truck ran fine but the engine light stays on now.
I am out of state and plan to drive 7 hrs back in a couple days.
Only way i can figure to remove the engine light is disconnect the neg battery terminal for a few mins?
Assuming its just a old error code now, not sure.
2016 Sport.
Thanks.
JB1
Houston, Texas
You can go to any auto parts store and they'll clear the code with a handheld scanner for free, then see if it returns.
RoadKing
RoadKing
Ga
2022 Bighorn
HEMI 5.7
I might start carrying my scanner in my truck after this.
unxpctd
Minnesota
2021 PW 75A
May be worth making sure everything is seated correctly (the clips I mean).
And don't run it in ECO mode...I also heard that (as was mentioned).
jasonw
South Dakota
5.7L Hemi V8
Just a note... many won't do that anymore. They may still read the codes for free (some are even getting rid of that!), but many won't clear them anymore for you. Liability issues, they say.
R.L.K.
Bristol , Tn.
When the engine light is on , it's not uncommon for it to stay illuminated for several power ups and shut downs aka driving 3-5 times before it resets.
Disconnecting the battery for a bit to overnight may clear a fault ; however, just simply disconnecting the battery will cause an engine light for 3-5 power up & shutdowns all by itself .
Hope this Helps !
Sent from my SM-G900V using Tapatalk
808ram1500
Big Island, Hawaii
4.7L
I had this happen to me last month. Deleted the code and it ran fine. Now my try is stuck in limp mode, 4th gear. P0750. I wonder if PC has anything to do with this? Probably not, as I have 82xxx miles and have read that the shift solenoid is a common problem. I'll have to contact PC to see if this could be related to PC.
Burla
2010 Hemi Reg Cab 4x4
hopes this resolves RK.
Orca
