- Mar 16, 2012
- 2,213
- 3,652
- Location
- Midwest
- 2012, 2021
- 5.7, 6.4
Instead of trying to sift through people's opinions in a forum about how they work, if you really want to know how throttle controllers work, the best thing would be to research them on your own. There's plenty of information out there. Throttle controllers are not a gimmick, they do work. The thing I notice most is there is no initial throttle lag the truck has with no throttle controller.
Plenty of misinformation as well.
Put a block of wood under your pedal that's tall enough that the pedal now 'floors' at 40%. Every time you go to take off, stab it as hard as you can until it 'floors' at 40%. I bet you'll note the exact same feel as a pedal commander that's set to take 10% pedal and increase the voltage to simulate 40%. Etc. etc. It's just easier to modulate because without a hard stop it's very hard for a human to quickly stab the pedal to a set percentage without overshooting or undershooting. Same reason new shooters who ride the reset of the trigger shoot so slow. You can't be both as fast as you can be and as precise as you can be, especially at an untrained/unpracticed movement. Body control has to be taught or we'd all be naturally graceful dancers. The PC isn't a gimmick, it's a crutch to allow more or less granularity so you don't have to be that ballet dancer on the pedal. But it also doesn't do anything past the ECU. It can't, it has no line of communication, and saying "I don't know how it does but it does" isn't information.
