Cmsharp
Read a couple of previous posts about this little gizmo. Wondered if anyone else has used this on their ram. I dont want to spend the money on a tuner since i have a 2016. Could this help my 3.21 feel like a 3.92?
Our 5.7l hemis have a fly by wire throttle system with no mechanical linkage from gas pedal to engine with a signifcant throttle delay built in by software. The Pedal Commander, and what I use, the Sprint Throttle Booster, have you attach a gizmo at the gas pedal which allows you to control how much delay there is of the gas pedal pressure signal from pedal to computer. Some allow several choices, I have mine set to "sport" which is a 50% delay ("race" is also available but I felt it was too touchy). Now my throttle response is nearly instantaneous which is great. Some of the tuners, Diable and Trinity for sure allow for throttle delay adjustment built into their tuner software without the gizmo at the gas pedal (my older BullyDog GT tuner does not, the newer BD product may but I do not know for sure). Any of these methods is so much better than the standard throttle delay which is truly annoying. Good Luck!
