Plenum
ramthis9501
Oklahoma
5.2 V8
Alright I'm about to get serious about my plenum gasket problem. I looked into the throttle body today and it has some oil in there, so def a blown plenum :Grenade: So I talked to a mechanic at the dealership today and they can get me a new plate for $35. Very suprising I thought, but from what I could tell it was the right one. Can also get the gasket for $20. Now the question, if I got it from them, would it be all aluminum or is it still cast like they used oringinally? I found the Hughes kit for $119.95 not including shipping. Which would be the better way to go?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I would almost bet the dealer plate is cast. You need aluminum to solve the problem. But a gasket alone will pacify the problem.
Sent from my DROIDX using Tapatalk
ramthis9501
ramthis9501
Oklahoma
5.2 V8
That's what I was thinking... is the Hughes kit the cheapest one around?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Not sure. Only one I've heard of.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Alright well that's probably the way I'll be going then
ramthis9501
ramthis9501
Oklahoma
5.2 V8
The Hughes kit comes with manifold gaskets to right? And im going to replace the thermostat, should i go with 180?
txbass06
NE Texas
5.9 Magnum
Im almost sure the kit will come with all the necessary gaskets. And I'd go with the 180 thermostat.
Sent from my iPhone 4 using Tapatalk
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Should have the manifold gasket and plate and plate gasket.
Bad Habit
Land O Lakes
Modded 4.7l
get with the guys at aps precision i believe, i bought my plenum kit that came with everything under the sun for like 180, the hughes kit dont come with bolts and stuff this does and is a nice 1/4" pc of aluminum well worth it....
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I totally forgot about the intake bolts. Good catch Jay. Colton those are one time use bolts. Not smart to reuse them. Best bet is to buy new.
sabo
