Post up your avg. Xsmn temps
Hemi395
Cape Cod MA
Was that 68k on the factory fluid?
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
I would like to know this as well. If it wasnt the factory fill that it happened on, what milage did you change it at?
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
2017 Bighorn Hemi after a 30 mile freeway drive to work
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I bet my temps will match those posted once I remove the TBV.
Here's a picture of my shifter. Please note distinct lack of dial and clear presence of stick and knob. Not pictured....knob taking picture :)
I know this is an old thread but it has come back around & I just wanted to say that is just a BAD A$$ shifter!
R.L.K.
R.L.K.
Bristol , Tn.
That is a bad ass shifter ![emoji16]
Hemi395
Cape Cod MA
Today it was 80 with 90+% humidity and on the highway for 20 mins this was my trans temp. Completely unloaded, just me in the truck. 65RFE, Redline C+, and MH trans pan. This is the coolest running transmission I've had in a vehicle.
huntergreen
Is your mag hy pan also extra capacity ?
huntergreen
Yeah it's about 2 quarts over the stock pan. I'm sure that helps with temps...
Thanks for the answer. Waiting for them to come out with a pan for the 8 speed. Doesn't look likely though.
Hemi395
Cape Cod MA
There are a couple of aluminum pans for the ZF 8 speed. The problem with the 8 speed is the thermal management system keeps the trans temps at around 190* at all times. Unless that can be bypassed, no matter what you do it will always hover around 190...
huntergreen
IMHO, extra capacity should keep the better for a longer period.
R.L.K.
R.L.K.
Bristol , Tn.
Well these temps are not normal but the results of pulling about 7,000 lbs of trailer and Tractor up a 3-6% grade for about 20 miles on a 45 mile total trip , had about 10 miles of flat land driving prior to hitting the uphill climbs .... BRUTAL switchbacks ! Near stop & go the turns are so tight .
Once on top of the mountain xsmn temp quickly cooled to about 150 and engine oil down to 210.
I have the Mag-Hyteck RFE45 pan on my 6 speed RFE65 xsmn with 3.55 Differentials . Running Redline C+ ATF+4 fluid .
This is the first time I've seen this fluid above 150° , and the first time I've seen my engine oil over 220°
huntergreen
It hit a 100 degrees here in Jersey yesterday, so I am a bit envious of that 73 degrees you are showing. Do you think a higher temp would have raised your displayed temps ? Good numbers btw.
AJAY
2013 Ram 1500, 6 speed, 3.92 and 35s
I had the transmission flushed and filter replaced at 65k. Could tell a big difference in the way it shifts. I am at 69k now and this is after a 45 min drive back from work @ 88F.
R.L.K.
R.L.K.
Bristol , Tn.
That 73° was a bit skewed as it was morning and I was at about 5,000 feet above sea level [emoji1303]
In Jersey your probably less than 200' ASL [emoji6]
And I do think my #s would've been a little higher but not much because the #s jumped up pretty quickly about 1/2 way up the mountain then they just kinda stabilized for the rest of the climb .
I was getting concerned when the temps went up so quickly , but the beginning of the trip was very very steep grades with really tight turns ( near stopped at times ) so slow going and very little airflow for the oil cooler .
Orca
