Project airlift 1000
redneckstylin
Prince George B.C.
pentastar
All went good took 1 hour time
I found 2 holes under tailgate area I mounted the valves to otherwise easy install
Sent from my GT-I9100M using Tapatalk 2
gofish101
2018 Outdoorsman CC
Looks good. What do psi you have them set at?
joeg45
Katy, Tx
Looks good the tailgate doesn't hit the valves when you open it????
R
redneckstylin
Prince George B.C.
pentastar
Tail gate doesnt hit valves I checked several times before I bolted them in
I have them at 15 psi right now took for a good boot doesnt squat as much when you give her some go juice
Im extremely happy with them so far
audio1der
Airdrie, Alberta
Aren't the valves a bit awkward to get the caps off? Looks kinda tight is all...
Airlift is some of the best $ you can put in a RAM if you have to tow.
h2oman
SoCal
Awesome. Good job dude.
gofish101
2018 Outdoorsman CC
Very nice! Any reviews on the quality of the ride yet?
I've had mine on for a little over a month at 15 psi and love the ride and great addition for only $90.00 bucks.
R
redneckstylin
Prince George B.C.
pentastar
Works good for me ive been checkin the air pressure all night no issues with caps
2nazt
VA
2012 1500 Big Horn
what part number did you run from airlift? I've seen a couple different ones used so far.
toofart
QC Canada
Hemi 8 spd
Nice job. It's on my short-list of things to do.
R
redneckstylin
Prince George B.C.
pentastar
Well hauled some tires with the ram she did good each tire was filled with rubber and half inch steel plate rims definitely noticed it but she hauled them no problem
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
hope you check back here, I have a question for you. Did you have a hard time getting the hose onto the bag once it was in the spring? or did I do mine wrong. I installed bag, then black doughnut, then hose. Mounted my stems like you did as well but putting the hose onto bag was a pain in the rear. I just couldn't get the clamp seated to my likening. I'm gonna get some angled needle nose and try tomorrow...
gofish101
2018 Outdoorsman CC
I used a little spit over the metal piece and the hose went on easy, then did the same thing on the hose and wiggled the clamp over. Push on opposite side when clamp is pinced then push down on clamp side and repeat lubricate as needed. Worked like a charm for me.
R
redneckstylin
Prince George B.C.
pentastar
What I did is jack truck up via frame rail next slide bag in coil next run airline through next black puck next ran line through blk spacer than lifted spacer up put clamp on hose further up than dunk hose end in hot water it expands a bit for a second or 2 slide on than bam onto next side
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
Ha... I think my jack placement could have been the issue
Musclemckeester
Houston, TX
n/a
n/a
On my install, I just stuffed the bag in between the coils. You don't have to remove the coils. Airlift FTW.
audio1der
Airdrie, Alberta
I just held the ring doughnut/ring up on top of my handwhile pushing the hose onto the barb. Once I slipped the clamp down I let the doughnut/ring drop and voila.
R
redneckstylin
Prince George B.C.
pentastar
Yes jack frame up extend coil.....nonneed to remove coils and lift doughnut up and do airline
ryss003
This really is a nice read!! Im planning on getting these too for i always have heavy stuff to haul and tow a trailer with atvs.. :)
