Rack and pinion
ScrappyDogg
Louisiana
I need a rack and pinion for 2014 ram 1500 5.7 4x4.. everyone seems to be out. Any ideas where i can get one. One company says they have a used one for $1300.. any ideas where to look?
Jeepwalker
WI
2012 Reg Cab, 4x4
This is one of those situations where supposedly the brand new racks have been improved and seem to be pretty reliable (but not cheap). If you plan on hanging onto your truck, it probably makes sense to seek out and bite the bullet on a new Mopar replacement, even if it means waiting a bit. Buying an older used one...might not be a long-term fix.
If you're pretty DIY and mechanically inclined, you could do some de-bugging right away. It might be something simple, like fuses up by the battery, wiring, etc. Those are easy and quick checks you can make. Watch a few Y/T videos. You're not alone. There are a lot of past forum threads on Ram EPS (electronic power steering) racks on this forum worth searching (or Google/Youtube search), which contain other debugging suggestions. Or maybe you've already done those. (??)
Cheers
Dodge 1500 4X4
Rochester, NY
Pull the inspection cover and check the drive belt, maybe you're lucky and that's your problem.
read this post by@Wild one.
Jeepwalker
WI
2012 Reg Cab, 4x4
The cover for the belt is on the pass side.
The cover for the circuit board is on the rear (square cover). They sometimes get water in them.
Swap the fuses up by the battery first (there's a Y/T video on it) before you dig down below. Might be that simple
