Ram 1500 Transmissions.
wsbf0917
I don't know the models of the Transmissions but it looks like there is several different options for the Ram 1500. Are the five speeds any good? Is any of them better than the others as far as durability or common problems? I'm looking for a used truck truck between 2009 and 2013.
Sent from my SM-G935T using Tapatalk
smurfs_of_war
Swift Current, Saskatchewan
If you can find a late year '13- that's when they optioned in the 8 speed. You may have to dig a bit.
Otherwise 6 is better than 5 any day of the week.
Sent from my SM-G935W8 using Tapatalk
W
wsbf0917
Can I ask what makes the 6 better then the 5?
chrism1367
I have the six and from what I hear it's pretty much the same as a five, one major regret I have with the 6 speed
smurfs_of_war
Mechanically I think they're near identical... I *think*... but I am a fan of the extra gear ranges to help with the torque curves. Maybe it's not a huge difference to some.
Neither will leave you stranded, but I think the 6 would be a better option. This is just my opinion on it.
W
wsbf0917
Good times. I've been really eyeball on this particular truck but it's got the 5-speed. I didn't know if it was something I needed to worry about. I appreciate all the comments.
JasonK94Z
Moore, OK
The 5 and 6 speed are the same transmissions. The 6 speed uses the the second 2nd gear in the 5 speed. 2 prime.
2 prime gets used in the 5 speed when in the tow/haul mode.
W
wsbf0917
Prime what it the fork does that mean? Never heard that term.
chrisp2493
Always Modding
Warren, OH
392 Hemi
Basically a “second” 2nd gear. In the 5 speed 545rfe, it’s used as the main kickdown gear for downshifting. It’s geared slightly higher then the normal 2nd gear that’s used for the upshift. They put it in there to make for a smoother downshift for highway passing. It’s generally viewed as a weak gear, you don’t want to do much full throttle downshifts out of overdrive, it is the best way to trash the transmission. d800e6100000511776e8e735ad19454c.jpg
W
wsbf0917
Ok now I see. Cornfused me a bit lol. I'm looking at a nice 2012 1500 with the 5.7 bighorn says it has a 5 speed but was going to look at it tomorrow so I will see for sure. But that's nice to know on the 6-speed take it a little easy out of overdrive before laying the hammer down sounds like the best way to go?
chrisp2493
Always Modding
Warren, OH
392 Hemi
Yep that’s the best thing to do. Also manually select the gear, wait for the shift and then floor it. I have an 03, but I think the trans is basically the same (not 100% on that) But if I’m rolling around 40-50 mph and want to go fast, I drop it to second gear, wait for it to shift and then romp on it!
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Never had a lick of trouble with my 5 speed. It is same damn transmission as the 6 speed. It has been very good for me but I think the 8 speed is much better and would be well worth the extra. I would also suggest gearing of 3.55 or better as it will give you more flexibility. If you get a 6 speed truck get 3.92 gears you will be happy you did.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
BTW I have 150k on my Ram.
RLJ10X
Southern Indiana
With the 5/6, I cannot over state the importance of pairing that tranny with 3.92s
I had the 3.55, and it was awful. Don't buy one with 3.55s!
W
wsbf0917
Well that sucks the one I'm looking at has 5 speed with 3.55 so I'm assuming bad for towing better mpg with this setup? Never delt much with rear ends other then a jeep I help build.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Yup mine came with 3.55 hated it for towing unless I locked into 4th gear. I switched to 4.56 gears.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
A friend of mine has a 2008 with the 5 speed. 260,000 miles, only one fluid change on it, and it still shifts just fine
With Torque management they are pretty durable.
RLJ10X
Southern Indiana
wsb, I put 4.10s in mine. I think that should have been standard. I believe some of the RCSB 2 WD R/Ts came from the factory with 4.10s. 4.10s are both expensive and a bargain.
I wouldn't even have an 8 speed with anything other than 3.92s.
Orca
