Ram 5.2 help with power
Discussion in 'Events Calendar' started by Terrance.skidgel, Aug 19, 2015.
  1. Terrance.skidgel
    Terrance.skidgel Junior Member
    21
    Aug 17, 2015
    Ram Year:
    1997
    Engine:
    magnum 5.2
    I have a 97 dodge ram 1500 5.2 manual single cab, I put in intake and exhaust, plugs and wires what else can I do to gain a little more power? I have a grand to spend on this. I tryd the cam idea but new vavpe springs are required and I don't want to replace the springs until I either rebuild the engine when it gives out or a different engine.
  2. PCT
    PCT Senior Member
    22
    1,576
    308
    May 9, 2014
    Northern California
    Ram Year:
    2013 Ram
    Engine:
    4.7
    How many miles, I had a 5.2 that was very sluggish, make sure that all the vacuum lines are not rotten, if they are either replace or cap them. Also I ran about a can of fuel injector cleaner, like seafoam. Mine ran much better with vacuum line restore and seafoam.
    What my suggestion, is make sure the engine is ship shape, before modify anything. You also have to remember the truck is nearly 20 years old.
    Have you done cap and rotor as well as plugs and wires?
  3. Kotta390
    Kotta390 Senior Member
    32
    1,078
    225
    Jul 6, 2015
    Ram Year:
    Engine:
    Check to see if there is oil in the bottom of the intake manifold. If there, is, time for a new plenum gasket....
    codered likes this.
  4. codered
    codered Senior Member
    19
    9,493
    2,117
    Aug 18, 2014
    in da ghetto, FL
    Ram Year:
    1998 QCSB
    Engine:
    magnum 5.9/360
    ^^ to follow up what this guy said you can pull your TB off and see if you can see oil pooling in your intake.
Share This Page
