Ram Smokes!
bigblock79
4.7L
my truck runs really rich, pours black smoke when its running, makes my eyes burn while at a light or stop sign, my o2 sensors are bad, can that cause the smoke?
B
bigblock79
4.7L
just had the cat reinstalled and the exhaust replaced yesterday, o2's are next, if that doesnt fix it, for sale sign
Cthulhu
Calgary, AB
Cummins 5.9
Yep.. if an O2 sensor goes, IIRC it will automatically run rich to ensure you don't end up melting crap with a lean condition... I'd put money on the O2.
B
bigblock79
4.7L
ok, replaced passengers side upstream and downstream sensors, cant seem to find the drivers upstream! Autozone says there are 3 total? my gas mileage has improved drastically, but still smokes black when i punch it but not nearly as bad as before
B
bigblock79
4.7L
is there a 3rd oxygen sensor on the 2002 4.7L?
B
bigblock79
4.7L
i hate autozone... on the bright side i get $50 back for my gas tank lol
Cthulhu
Calgary, AB
Cummins 5.9
You would probably do good to reset your ECM by disconnecting the battery for a few hrs.. I'm sure someone on here will give the required time to have it disconnected... That'll get the ECM to start relearning the parameters your truck is supposed to run on, versus the messed up ones your O2 was feeding it.
B
bigblock79
4.7L
ill unhook it tonight and hook it back up before work and see what happens but in pretty happy now with the gas mileage being 3x better
B
bigblock79
4.7L
lmao, just found out today, after all of this electrical, i changed the oil and now i have a low end noise, sounds like bearing... any idea which dodge vehicles other than ram and what years are interchangeable? its a 2002 4x4 auto 4.7L
Cthulhu
Calgary, AB
Cummins 5.9
Free bump to the top for the bearing question....
Did the ECM reset sort out your smoking issue?
B
bigblock79
4.7L
i was working on the truck late last night when i realized the engine was rattling and forgot to unhook the battery, ill go do it now since its too hot today to do any real work outside lol
JustinRam1500
