Rambox Conversion Question
msandy922
Cary, NC
Hemi - 5.7
I've searched on these forums and on google in general for an hour or two, and have even called a few dealerships and can't get a definitive answer, so I'm asking desperately for some help!
-I have a 2012 Crew 4wd w/ 5'7" non-rambox bed. The bed was smushed by a tree and I want to replace it with a rambox bed.
-I found a color-matching bed from a 2021 Classic. I don't know the cab size or if it was 2 or 4wd, I only know it's a 5'7" rambox bed.
The dealers are saying the frames share part numbers for both bed styles from 09-12, then from 14-21. My guess is this is suspension and/or drivetrain mounting point related, but I don't know.
Does anyone know if this would be a direct swap? I'd go do some measuring but I'm several states away.
Thanks in advance!
Daw14
Stop by a dealer and look at a truck on the lot for measurements, my guess is just the carriage bolts need to line up . If they match ,should bolt on.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Chrysler Owned Dodge Ram up to June 30th 2012
FCA officially took over from Chrysler on July 1, 2012
They only made mostly Cosmetic changes until around 2017/2018
if you follow the Browser Instructions, you will be able to find the Wiring schematics
oe542bob
Hemi eTorque 5.7
I know they still build the ”classic” model, but I didn’t think you could get the Rambox on any Classic model since the 5th gen 1/2 came out.
