mws1369
Rattle up under the fuel tank? How do I determine what it is? 2004 Ram 5.7 4 door
I suggest clean it first with a good blow of water, could be dried mud you never know. then eliminate things one at a time, like a broken wire, loose nuts, loose straps etc. The last thing you want to do is drop the tank as that is the most labor intensive.Rattle up under the fuel tank? How do I determine what it is? 2004 Ram 5.7 4 door
I didn't think of that BUT my first thought was "up under the fuel tank" ? What ever is -under the tank should fall to the ground.Couldn't help it..........
I don't have a problem but I don't have a bore scope.Get yourself a cheap borescope like this and look around up there.
