Ok guys, I really don't want to lift but I have to in order to have the rear clear a retaining wall. I need a full inch and a half to make this happen. If I go with a 2" lift, is it actually 2" or do I need to step up to 4"?
A two inch lift would be a leveling kit. That bring the front up 2 inches. You will have to find a suspension lift kit that has at least a two inch lift in back.
Would a 2" body lift help? If you are just trying to get your bumper over the wall, that might be the ticket
Just go 6inch and 35”s and be done
It would be 5.5 up front and either 3 or 5" in the back, depending on which springs you choose and how much rake you want to retain.Possibly... Is that a true 6" all around?
I only need the bed to clear it (1.5") and need the bed to go back over the retaining wall about a foot or 2No matter what lift you do you are not going to change the height of the diffs except for increasing tire size. Everything on a lift is done above the axles. This is where portal axles are a huge benefit.
Yep that's right mohemipar I didn't finish my statement.
With a 6 inch suspension lift you can put on 37 in tires and that will get you closer to that 2 inches of lift that you're looking for.
