About 25.75 inches to the bottom of the hitch receiver.
I covered this before brother... I'm not going back that far and I'm not lifting my axles 20"s lol.My post is for ground clearance at the lowest part of the truck. This would be your axles and the only way to gain ground clearance at the axles, is bigger tires.
If you bought a Zone 4” kit with 3” rear coils it will raise you 3” in rear, add the 35’s and you should go up another 1”. That lift in stock form only eliminates 1” of rake, if you want to eliminate more buy a set of Bilsteins and adjust them to what you need to eliminate more (most do around 1.4” setting).Will a 4" lift on stock 20s give me a min of 2" on the back end of the bed?
A lot of times a 4" lift raises the front 4" and the rear just enough to level it. Check on the kit you are getting
20 is wheel diameter, the 60 is the aspect ratio meaning the sidewall is 60% of the tires widthI thought 60r20 is my stock size
.... I understand that... I'm telling you that my stock 20s come with the "60" sidewall... So the tire you suggested would keep me at stock height but they would be wider
It seems to me, that everyone is making this way to complicated for the OP. His first post states that he just needs the rear bumper to come up 2" to clear the retaining wall. Simply put, a 4" lift kit with a 3" rear spring option will get you there. That would raise the rear end 3"!!!. IF you wantes to run larger tires, say 35's. You would then raise the rear end another inch. There is your answer.
