Rear Track Bar snapped? Or was it cut?
Justin33
Get us a closer, better focused picture of the part where it broke, like an end on shot. Looks like maybe there are teeth marks in the thing from a saw. Not quite sure though.
I don't see any evidence of a stress induced failure of the parent material, leads me to believe that it was cut.
I did swap my OEM bar for a Core 4x4 bar and once I did the swap, it was obvious my OEM bar was bent. I would think that a factory bar failure would look different though.
How did you know the oem was bent? I’m trying to figure out why at 70 or higher on interstate my truck feels like it is shaking? I’m not sure if it’s cuz I have new duratracs on it, the four inch lift or maybe this bar has gone to crap?
G-Ride990
Administrator
Administrator
Chandler, AZ
It was obvious once I set it on the ground after replacing it. Couldn't tell when it was still on the truck though.
Justin33
This wouldn’t cause shaking at75 right? I’m starting to think my duratracs might be the issue.
Hardracer
2010 1500 laramie 4x4 crew cab
Looks to me like half cut then snapped...theres rust and there's shiny.i also see teeth marks
Justin33
Sounds like a bad balance job. Could be bad ball joints or loose steering linkage too.
I just.had ball joints replaced maybe I can get discount tire to try and road force balance them.
Rasworld84
Cleveland, TN
Justin, im having the same issue with my Ram 1500. 4 inch lift and added GoodYear Wranglers ultraterrian A/T tires and it shakes just in the rear going 70mph. It drives fine under 70mph. Having the tires Road Force Balance today to see if that helps. Any luck with yours?
Dean2
Near Edmonton
I would not worry about what caused the track bar to break, just put on a new one. I would also check out the rest of the lift and make sure it was done correctly.
With respect the vibration issues; Large off road tires are hard to make perfectly round and evenly weighted. If it takes too much weight to balance the tires make them replace the tire. Last time I bought tires they went through 7 to get 4 good ones. This shop is great becasue they won't mount out of round or out of weight tires or tires that take too much weight to balance. Not all tire shops are anywhere near that good at what they do.
You can Road Force balance and it helps but if the tire has belts that aren't evenly laid down, more weight on one side etc, at some point that is going to show up in how it behaves.
Justin33
Let me know if that helped I have a empty gum container I sue for change and it shakes the shut outta that like a Salvation Army bell.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
My 11 crew cab sport 4x4 no lift kit, vibrated in the rear at 70. Sold not forgotten.
My 16 crew cab Laramie 4x4, no lift kit vibrates in the rear at 70.
Multiple sets of wheels, factory and aftermarket, Multiple sets of tires over 230k miles combined.
Drive 65, no vibration, drive 75 no vibration. Drive 70 vibration. Got to be in the design of the vehicle. Probably drivekine related.
My 14 RT, does not vibrate at any speed. Aftermarket 5 inch driveshaft.
I'm thinking and it's a hunch, it might be driveline related. Maybe Carrier bearing, maybe driveshaft, could we control arm bushings, etc.
Last, doesn't seem to reveal itself if loaded or towing.
My thoughts
