Recall #8
sandawilliams
Pueblo West, Co.
6.4 hemi
Just got my EIGHTH recall on my 2014 2500. This is another on the track bar frame bracket. The first recall on this was inspected by the dealer and determined it wasn't cracked. This new notice mentions inspection, if not cracked then brackets will be added to strengthen the bracket.
These recalls are really getting old having to take the truck in numerous times to fix Rams screw ups. They need to bring their manufacturing back to the USA and maybe we wouldn't have as many problems. Just my rant for today.
mtofell
Keeping track will just lead to you being annoyed. I take mine in for oil changes and just have the things taken care of then. I don't believe it's a matter of worse manufacturing but rather more complex vehicles (and more attorneys chasing problems).
MADDOG
Out Exploring Arizona
8 isn't an abnormally high number. I've had worse from GM, Ford and Chrysler.
#8 is a bit of a double up on the same thing but that's because FCA was convinced that inspection was not the solution, even if no cracks were observed. So they have to do it all over again and, this time, install the brackets.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I think they are having more problems with the 1500 in Warren Michigan. My opinion is that the 6.4 is a new motor for the HD trucks & they are still working the bugs out. I don't think they are having as much trouble over the last 6 months with it.
sandawilliams
sandawilliams
Pueblo West, Co.
6.4 hemi
I bought a new 2004 and 2009. (1500's) Never had a recall or any problem with either one. Both made in USA. Probably not the problem but more of an engineering fiasco. But I would still like to see the jobs come back here.
derag2
6.4 hemi
I think the are repeats.... I got that one plus today I got another one for the wires under the steering column.
mtofell
I just got home after reading this and the recall notice was in the mail. I called the dealer and he was still thinking it was just an inspection thing. When I read the letter to him he admitted he hadn't even seen the notification that it's more than just an inspection now. Sounds like they need the truck for 3+ hours. It could be several days if they find the actual failure.
WaterBoy1
Ontario
2014 Laramie CC2500 Black Edition
Meh, these recalls don't bother me. As someone mentioned above, GM and Ford both have had many recalls.
For me, I'd rather they were proactive like this instead of waiting till enough people complain about a problem.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Yeah, I receive one the other day, or should I say another one for the same thing I will go to the dealer and see what they say but I'm planning on trading it in anyway.
sandawilliams
sandawilliams
Pueblo West, Co.
6.4 hemi
Yesterday I called the dealer and questioned the new recall as they had inspected it before and said it was OK. They explained that the new recall says they must re-inspect and if not cracked they HAD to put on the additional brackets. They ordered the brackets and scheduled me for three weeks out to bring the truck in for repair. About three hours to complete.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
i personally think it's not WHERE it's made,more like where are they sourcing the materials from.maybe using too much recycled crap?
daynawide
massachusetts
6.7L Cummings
Had it done Monday took all day but they gave me a rental.I was the first one they did.It went ok not a big deal.
loveracing1988
Clarkston, MI
Can you post a picture of the reinforcement bracket? I'm not too keen on them drilling holes through my frame.
Tach_tech
5.7L HEMI
There's about 5 holes that have to be drilled. What are you worried about? The holes aren't going to weaken the frame if that's what you're worried about.
This is what it looks like installed.
loveracing1988
Clarkston, MI
Well, if a competent person were to do it I wouldn't be as worried, but most of the techs at local dealerships take 4 trips to fix a simple spoiler rattle let alone drill holes into a frame in the correct spots. My main concern is corrosion though, that bracket, bolts and inside of the frame will be covered in rust in one Michigan winter.
2robinhood
2016 Ram 3500 SRW crew cab
6.4l gas
I'm going to take a look at my 2016 and see if mine looks anything like that.
RAMYOU
Is it just for the rear?
Bigdaddy
6.7L Diesel Cummins
I have an appointment on the 14th to have mines done.
Lowrider357
