Recon's Installed and a question
ramhunter9
ramhunter9
P-Star Jeep Wrangler
Thanks Trup .
I have to call recon monday . I dont understand there thinking in the white wire .
truckin151
2013 sport
Looks great man!! Wish I could help with the fuse issue but electrical is most definitely not in my bag of tricks.
Gotta give you props for drilling into the roof on a $30k - $40k+ truck. I'd **** myself if I did that.
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
dave, 35 is the dome fuse. if you are hooking right up to that fuse and getting constant power to the light, that makes perfect sense. the fuse location is getting constant power. its not until after the door switch that it turns on/off when the door opens. my best guess is that you need to hook it up to the wiring in the cab to goes to the dome light itself.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
Your close oldj, The wire he is looking for is the one after the dimmer relay. Thats the on he wants. Pull the dome locate that wire. by a test light. activate light, if the test light dims ,thats the wire. I haven't a clue where it feeds into the cab but the color should be the same there as it is at the dome. Hope it helps dave, Ya got some balls, drilling into that rig, I would of been nervous as a ****. lmao!
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
so what we chatted about didn't work?
RubberFrog
Why would you call JJ? He only knows about head lights. lo.
There's one more panel right here-
4XLGATOR
CTD
Looks awesome, RH. Good luck getting the door light wiring straightened out.
ramhunter9
ramhunter9
got it . Thanks JJ .
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
so its working now?
ramhunter9
ramhunter9
ya , but the wires were not correct , had to hook inside truck .
Dont matter anyway , Im taking off the door lights .. For sale if anyone wants them , my truck is to high in the air and it looks like I have neon lights .. noy diggin that . Might try mounting them under the bed rails
Ram Man
FL
2013 Sport
On my 04 the dome light wire was behind the a pillar and was a yellow w/ blue stripe.
Cab lights look great!
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
:) Looks good Dave. How about a Pic of the roof in daylight? I'm jelous you have Hobby Time, I've been running around as a Taxi Driver and can't get time for anything.
Because of your cab Light Idea, I did manage to order a complete Mopar OEM Cab Light set-up for $87.10 at the Dealer and will upgrade to the Recon Lenses later from Duane (OEM's were 124 Plus Ship on your site).
So what else can i copy from Ya....LOL..:grd:
Orca
