Retroshop HID Headlights/Foglights install photos.
User
Fort Worth, TX
2014 RC Black Express
Got these in on Friday, finally got around to the install today. First and foremost, I must say this was an effortless install. After installing HIDs on my 2001 Dakota, this was nothing.
I enjoyed the fact that the CANBUS adapters bypass the harness and allows you to use the factory connection to the headlight with no wires hanging anywhere.
I was also able to kick up my Tetris skills and fit all the connectors and parts in the headlight housing, even the CANBUS adapter, regarding this, I noticed on the other harness the youtube video states that the solenoid/resistor gets very hot. I'm assuming the CANBUS adapter doesn't? I didn't see anything stating not to install it in the headlight. On the same note, I was able to get the dust cover to seal too.
I went with 50W 6000k headlights and 35W 6000k foglights.
Here are the photos;
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
boom!
Yeah, tetris is about right!
And no, the canbus adapters won't get hot like the resistors. Warm, sure. not hot.
And thank you for your order! I appreciate it!
Munky
Reading, PA
2016 Ram 2500 SLT
6.7L Cummins
Night time pics!!! I think you just sold me on exactly what to get for my 2013 Blackout Express!!!
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
User
User
Fort Worth, TX
boom!
That's great, I'm a bit of a pessimist when things go "too" smooth, and was expecting someone to say you cant put them in there.
Thanks for the kit.
They look great. Gives me a good Ideal of what mine will look like. Thanks for posting.
No Problem.
I'll get more pics as the day progresses, right now I'm about to go play some corn hole. :3638400157_e7de35b0
BlackRamHemi
Edmonton Alberta Canada
I hate messing around with wires on the new computer controlled vehicles,
So I've been a bit gun shy about HID upgrades on my Ram.
The new canbus adapters were one of the main reasons I finally jumped in with both feet.
I've had my RetroShop murdered out 13' heads in for 2 weeks now
but the upgrade bug bit again and I placed another order today for the full FXR upgrade on some TYC's
:crazy:
fogs and tails are next
LB3711
Trumbull, CT
3.6L V6
nice. jealous for the 13+ lights. Love to upgrade lol
Hemi_Express2013
Nantucket, Ma
:crazy:
Oh yeah, the tails will seal the deal. Sign me up
danmp
Québec city, Canada
I love so much those projector headlight. I will make the switch for sure, if someone one day find a way to put the drl on the amber led like the factory canadian truck. I really love the look of the led drl and the projector for the hid.
clgrandorf
DFW, TX
2014 1500 Sport 4X4
Looks good! How are the fog lights done? Do you go through the fender liner?
User
User
Fort Worth, TX
Nope, I'm not sure what it's called but 2 square beams sit about 9 inches away from the fog light housing, since the CANBUS adapters let you use the factory connection for power, I just mounted the ballasts on those beams, they already have pre drilled holes that fit the factory hardware that comes with the ballast, I just double nutted the threads and zip tied everything back up into the factory wiring location.
Works great, like I said, easy install.
Here are some other photos from last night.
clgrandorf
DFW, TX
2014 1500 Sport 4X4
Okay, sounds pretty straight forward. It definitely looks a hell of a lot brighter than stock
User
User
Fort Worth, TX
Ahh, you want me to solve for Hella?
1100/(3500 - 1100) = Hella
1100/2400 = .4583
Hella = 46% brighter than stock
(This is estimated, output varies with different variables like ballast wattage, and Kelvin Temps.) The above is based on 5000 Kelvin Temp and 35W ballast.
I am using 50w ballast and 6000 Kelvin Temp. The higher Kelvin temp might moot the extra wattage, which could possibly return roughly same percentages.
So, I would say it's almost 50% brighter than stock. Big difference, that's for sure.
Jack Archer
San Antonio, Texas
5.7 V8 Hemi
I've been wanting those lights for the past few weeks. If only I had the money. I'll have them by early next year for sure.
Sent from the past five days ago in the future just now.
11BPSMIKE
Quispamsis NB
How do you find the color, is there any blue to them? Also are the fogs and headlight a bit different color. I am worried about this with the different wattages. I'm ordering soon and was happy to see your post.
User
User
Fort Worth, TX
Color is based on the Kelvin Temp. scale, see below. 6000k has a tint of blue, but is mostly white in color when directly looking at it straight on. The blue tint makes it harder to see in the rain, so I would stay below 6k if you drive in rain more on a regular basis.
Wattage output from the Ballast does increase lumen output along with heat, as the Kelvin temp gets higher than 6k you lose lumen output, but if you increase ballast wattage it should moot the results, I have not sat down and done the math on it, but I think it's safe to theorize that the differences are miniscule (not easily noticed by the human eye). However projector lenses and normal halogen reflective lenses disburse light differently, which may give the illusion that one is brighter than the other due to excessive glare from the other. Since the fogs are not projectors and the heads are you can see how this may effect the view point depending on the location you're standing, which is called an illusion.
PS: here are some photos of in cab while driving with the fogs and heads on.
Warl
Corpus Christi, TX
I really want to pull the trigger on buying the HID kit and the fog light kit but the color not matching is making me second guess myself. Are the headlights really as white as it seems in those pictures? I'm looking more toward the color of the fog lights to match.
BlackRamHemi
The perfect color match will be difficult to achieve
mainly because the amber LED's are distorting the appearance of the color temperature from the projectors
Personally I would just go with 35/5000k for all lamps and call it done!
it will all look perfectly matched from your drivers seat ;)
Warl
Corpus Christi, TX
But the blue! :( hah. Too bad he doesn't go above 6000k and maybe mix/match the bulbs. I think I'll be able to deal with the minor differential.
