Sensor sealant
Atcer2018
Virginia
Advice needed. On OEM sensors that come with fitting sealant already applied is it recommended to also use Teflon tape? Specifically oil and coolant temp sensors.
jws123
nj
As long as its new and has that on the threads I just install it never a issue if you remove/then re install or something then i would use teflon tape.
Atcer2018
Atcer2018
Virginia
As long as its new and has that on the threads I just install it never an issue if you remove/then re install or something then i would use teflon tape.
Thank you I appreciate your advice.
No,but as JW said if it's been in and out once or twice probably,but i'd use pipe dope instead of teflon tape
Joey93
