side view mirror replacement options 2023 classic warlock
Tony15068
PA
3.6L V6 24V
Just leased this 1500 Saturday. Did a ton of research, including fitment in my garage because the house was built in 1955 and the garage is smallish. Focused on the height which barely fit my 2019 classic and took a tape measure to the dealer to measure the height of the 2023.
It was the same but the manually folding side view mirrors on the 2023 are wider and I have barely one inch of total clearance which is not enough of a margin.
Yes i can get through the garage opening if I manually fold the driver side mirror but if it's pouring down rain the interior of the cab is always going to get soaked.
Anyway, was wondering what my options are. I know I can cancel the lease because it will have been within the grace period but I'd rather not do that and they don't have any other comparable vehicles with the power folding mirrors.
So, what are my options?
1. I know it would be expensive but can the manually folding side view mirrors be replaced with power folding mirrors (I realize I'd also need the appropriate control pad)?
2. At least from the outside, both the manual and power mirrors look to be the same physical footprint so is there a way to retrofit the manually folding with the powered internals?
3. Is there a smaller footprint manually folding mirror that I could swap out, oem or aftermarket?
Thanks.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
does your lease allow you to make upgrades ??
Power mirrors require;
power mirrors, choose from 2 or 3 brands
power mirror/window arm rest control panel driver/passenger doors
Door Module, drivers/passenger doors, need verification
Images are just for an example, check for correct model numbers
T
Tony15068
PA
3.6L V6 24V
I'm aware it's more than just the mirrors and I'm not sure about permission for upgrades. Will be talking to the dealer either tomorrow or Tuesday at the latest.
Administrator
You could swap to a set of aftermarket power fold mirrors, when you go to turn the lease in back in the dealership isn't going to even notice if they look like the factory mirrors and work. You could always keep the original parts and then put them back on before you turn the truck back in.
T
Tony15068
PA
3.6L V6 24V
Does anyone know how to determine the part numbers of the mirrors and associated components that are currently on my truck? This would give me an idea of what other mirrors / components might be compatible from the mopar website.
Thanks.
Gregket1
Oregon
Give Benny from AllMoparParts.com (vendor on the forum) your VIN. He can tell you exactly what you have and exactly what you need.
T
Tony15068
PA
3.6L V6 24V
Thank you. Sent him a PM.
T
Tony15068
PA
3.6L V6 24V
Well, the dealership essentially blew me off today. They said that even if I bought OEM / Mopar parts from them that they would not install them. Reasons cited were the "probability" of complications from having to "splice cables, etc." and other such nonsense.
NCRaineman
NC
2019 1500 Classic
Your best option is to join millions of other people with older homes and park your huge 4x4 truck in the driveway.
Cars keep getting bigger, garages don't. Sucks but that's the senseless world we live in.
T
Tony15068
PA
3.6L V6 24V
Does anyone have an idea why I keep getting this message when I type my VIN # in the mopar website? Is it because I just got it this past Saturday and maybe it takes some time for it to get purged from the dealership inventory?
No results found for "1C6RR7GG2PS554848". Here are some helpful search tips:
  • Search by a part name. Example: water pump.
  • Be less specific. Example: brake instead of ceramic brake.
  • Remove information such as make, year or model.
  • Can't find the part you are looking for? Contact us and we'll find it for you!
PaleFlyer
Charlotte NC
Dealers don't want to do much work on the vehicles anymore. If it takes any real effort, they "lose" money, versus the ability to just toss the cars on the lift and run the "normal" maintenance.
Heck my old work truck had a broken tail light cover, could have done the work myself for $100, but company wanted the dealer to do the work, and it cost us almost $800, just to swap the tail light assey.
F the dealers.
My sister also got told her Silverado 1500 can't have power folding tow mirrors, as it isn't a Chevy Supported Option for her '17.
I don't ask the dealer. I ask this forum. Plus I'm a Controls Engineer, so my literal job is to make shti that shouldn't work together, work. So hacking crap like that is "tuesday" to me.
The only thing that comes to my mind, is you are on a lease. You really shouldn't screw with the truck on the lease.
GTyankee
3.0 ecodiesel
VEHICLE HISTORY REPORT
2023 RAM 1500​
VIN 1C6RR7GG2PS554848
2023 RAM 1500 SLT QUAD CAB 4X4
VIN
1C6RR7GG2PS554848
3.6L V6 24V VVT ENGINE
Transmission
8-SPD AUTO 850RE TRANS (MAKE)
GTyankee
3.0 ecodiesel
CODE Break Down of VIN : 1C6RR7GG2PS554848
numbers 1 through 11
1 ) is Manufacturer Stellantis
C ) is Country Built In USA
6 ) is vehicle type Truck
R ) is weight class 6001 - 7000 LBS
R ) is Drive Wheels 4WD
7 ) is Cab Type Quad Cab
G ) is Model SLT
G ) is Engine Size 3.6L
2 ) is part of a mathematical equation, has no meaning for us
P ) is the production year 2023
S ) Where it was built Warren Michigan Truck Assembly Plant
Last 6 digits, indicate the sequence number of Rams that rolled off the line 554948
Administrator
One is the country code (1 USA) (2 Canada) (3 Mexico)
Two is the company
  • vin.pdf
T
Tony15068
PA
3.6L V6 24V
I think that is strange, that i could look up that information
The Equipment Listing is now available
I also see that you do have POWER FOLDING TOW MIRRORS
I don't see that text "POWER FOLDING TOW MIRRORS" when I do a text search in the pdf document? the only "FOLDING" that turns up in a word search is for the rear seat.
All I'm seeing in regard to the mirrors is this:
POWER BLACK TRAILER TOW MIRRORS
ALL VEHICLES W/POWER MIRRORS
GPS ANTENNA INPUT
MANUAL ADJUST SEATS
SPORT TAILLAMPS
EXT. MIRRORS W/SUPPLEMENTAL SIGNALS
EXTERIOR MIRRORS COURTESY LAMPS
TRAILER TOW MIRRORS
BLACK EXTERIOR MIRRORS
The two entries I highlighted in yellow I think that means the mirrors themselves are power adjustable, which they are. But there is no button on the switch bezel to press to fold and unfold the mirrors.
Where did you find that document if you don't mind telling me. And thanks for posting that.
GTyankee
3.0 ecodiesel
I apologize,
i read the page & with all the Meds that i take, i must have assumed the word folding had to be there
GPS ANTENNA INPUT
MANUAL ADJUST SEATS
SPORT TAILLAMPS
TRAILER TOW MIRRORS
T
Tony15068
PA
3.6L V6 24V
No harm, no foul. My brain fades are becoming more frequent and I'm not even on any meds.
