While engine is running it has a loud and constant squealing, I watched a video where someone sprayed water on the ribbed side of the belt and if the squealing stopped then it was a problem with the pulley alignment or wobbling pulley. When I turn on the truck and watch the pulleys it looks like my harmonic balance/crank pulley is wobbling. I recently changed the belt so it is not a worn belt. I also had to replace the timing gasket so I had to remove the harmonic balance to do so. Should I just be able to tighten the harmonic balance more and stop the wobble or will I need to replace it?
